Opinions on Oil...Rotella T Triple Protection?
- koolaid_kid
Re: Opinions on Oil...Rotella T Triple Protection?
06 Sep 2013 22:01
No way. It is 15W-40 for the win.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- 4TheKZ1000
06 Sep 2013 22:09koolaid_kid wrote: No way. It is 15W-40 for the win.
yep..my bad 15W-40
- lilsnotnosedtommy
06 Sep 2013 22:44
Yep still marked on container last line JASO MA so it's good.
I'm leavin mine in no need to change now.
The old 79's runnin great love to hear it bark
Talk about a time capsule nothin beats this!
ALSO...if you're having clutch slip issues FIRST before anything
check the adjustment screw under the door on LH side of case (on 77-80's anyway)
Mine was WAAAAAY too tight...had to back off a half turn b4 it even loosened up!! :woohoo:
Backed er off, turned just until I felt it start to resist, then backed off half turn and locked er down.
Took er out, got into the torque range 5-6500 NO SLIP...pulled like a Mac to 100 then backed it off.
That's all mine took, and the first thing you should check.
- SevKZ9
08 Oct 2013 13:16
I ride a 76 KZ900 that I just rebuilt.
So I just changed my breakin oil out from the rotella 15-40 to the 10-40 that is recomended and was hoping that would alleviate my inability to get into neutral... but it didnt. I still cant get into neutral until the engine is off.
Also I can feel the bike trying to pull just a little even while I have my clutch handle pulled.
Also my bike doesnt want to coast if I pull the clutch at hwy speeds, just starts slowing down quickly like the clutch is partially engaged.
advice on oil? should I switch back?
Are these KZ's always tough to get into neutral?
Should it coast better? or is this behavior typical of a wet clutch?
- Cynjut
08 Oct 2013 15:36
Sounds to me like your clutch isn't disengaging. That's the only time my '77 was hard to get into neutral.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- bountyhunter
08 Oct 2013 15:45You should adjust the clutch throw out assembly first. It's not typical.SevKZ9 wrote: I ride a 76 KZ900 that I just rebuilt.
