- Thank you received: 15
Is the KZ1000 engine worth rebuilding?
- peavylotus
- Movin on up
I understand you have to baby them with maintenance and upkeep, which I am completely ok with. I just want to see how long a rebuilt engine last's because these parts aren't cheap at all and I am already pretty deep with this engine.
P.S. taking note that I want to ride this bike frequently
1980 KZ 1045 LTD Currently Workin' It Out
- crh
- Banned
- Thank you received: 20
For the amount of money you can sink into it, you can buy a turn key motorcycle that just plain does everything better because it's more modern. Then again, there's the "cool factor" of riding a nicely done old Z. What's that worth to ya?
- roy-b-boy-b
- Thank you received: 103
- Motor Head
- Thank you received: 391
- dbc92s10
- Thank you received: 5
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
- zed1015
- Thank you received: 1554
If you do it's been built wrong and the owner doesn't know what they are doing and should probably never touch anything mechanical at all .
I've screwed my Z1R motor nearly everyday for the past 18 years since I built it and I mean everyday as i DON'T have a car or other regular bike.
It gets an oil and filter change when I remember, new plugs about 6 years ago, a shim check every couple and balance the carbs when I feel it needs it, which is rarely.
These are one of the toughest motors ever built and this fact is backed up by the thriving businesses that are still springing up around it all around the world.
Z1 enterprises , Hoopers pitstop , bulldock, sanctuary , Debbens, APE etc etc.
If the motor was fragile i doubt many of these businesses would exist never mind still produce high performance parts and mind blowing specials from them.
If you build that motor right it WILL be an investment, WILL reward you with years of trouble free riding and STILL be .....
OH! HANG ON, i've got it all wrong, don't waste your money on it, i'll take it off your hands for free, where do you live :laugh:
- peavylotus
- Movin on up
I am glad to hear that the maintenance issue wont be a thing.
I became under that impression when I got the bike, I was a entry level mechanic at a motorcycle shop and the guy who brought it in had a few different pairs of hands all over it.
So I was constantly dealing with the quirks of badly adjusted carbs, torn carb boots, ignition problems, fuel leaks and most of all wiring issues. Because of all that I 'hacked it' and went bare bones.
Then I went two days without checking the oil...So I have gotten new pistons with a bore up a size to the 1045cc and looking for a new crank to change, jetting carbs right and lastly and most expensive...valve train sprockets and guides, carb boots and the list goes on.
All in all I am ok with spending the money and time I just needed some reassurance that It will be worth it and reliable from you more experienced guys.
- roy-b-boy-b
dbc92s10 wrote: Just buy a new bike you'll be better off
Don't think so. $14,000.00 will buy a few engine rebuilds.
- zukdave
- Thank you received: 229
about the KZ motor's I think their about the tuffest
of the old two valve motor's.
Now my little GPz750 motor I beat on it REAL bad every time
I ride it.
It get's an oil change when the oil in the little window
start's to turn dark from sliding the clutch
other then that I ain't done shit to the motor.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- NakedFun
- Thank you received: 99
Are unexpected problems a PITA, absolutely. With that being said, what else are you going to do? If you don't fix it, it will sit as a worthless pile of parts. Owning mechanical things, especially old mechanical things require tough freakin' love! Can't get bogged down in the lows, but appreciate and be proud you are one of the few that can own and use an old bike and not play weekend warrior like most Ducati owners!
Man up, get the bike together, and ride the damn thing!
Pep talk over.......
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
- geerbangr
- Thank you received: 4
1978 KZ 1000
I go by Jason
- MDawnz1
- Thank you received: 27
Done right.
With a little bit of care.
Minimal maintenance.
and semi sane riding.
It just might outlive you.
But if you do decide to give it away PLEASE PM me.
Mike
1974 Z1a, still 903
