Radical streetable engine size
- Powerstroke_fan
Re: Radical streetable engine size
22 Nov 2013 16:45
It depends on what size motor you decide on, but main studs may not be necassary. But the list will be long. Just a few will be welded/ indexed possibly balanced crank, what crank will you be running. You will want the trans backcut. New camchain, new idlers, I replaced all the sliders. It was all new. I replaced my clutch and added lock up. If your going thru that much work you wont wanna half ass it. All the new seals. Thats just in the bottom end. You still have the pistons and jug. you will want to know which dirrection your going for the motor. I built mine with low compression. But it will be street ridden. The head will need money put into it also. You will at mininum want to lap the valves if can get lucky enough that they will seal. but will probably should just do a valve job. Then if your building a big motor youll want to port it. Then on to carbs or turbo. Then addressing the situtation of getting the power to the ground. Thats just a start iam sure i left allot of stuff out. But you start to get the picture.
1977 KZ 1000 work in progress
- geerbangr
22 Nov 2013 16:56
Well I must be honest. I will run the nuts outta this engine. Are there stroker kits for the kz1000. I'm thinking about heavy duty parts from the get go. Hell I may hang a hair dryer on it somewhere down the road. But for now I'm thinking heavy duty studs and lightening the crank. The whole stroker idea excites me a little. I don't want to have a big oil slobbering engine so I'll shy away from the big inch engines.
1978 KZ 1000
I go by Jason
I go by Jason
- Powerstroke_fan
22 Nov 2013 17:15
I havent heard of any "stroker kits" for these motors. The most you could have done if you want a faster rev is go with a 900 crank. I believe they will rev the fastest. Myself i went with a mk11 crank. Its got a heavier rotational mass, but its alot stronger. I Having good hopes that i will be able to seal mine up this winter for good. I got the base gasket to quit leaking, but then it started leaking at the head gasket. i just cant win. But i am confident i can get the head gasket to seal this go around. Thats the first head gasket i had leak on me forever, it seems.
- spdygon
23 Nov 2013 14:42
Racer54 that is a nice looking bike.
I now my brother on his 78 mk2 was running on the streets a 1327 kit with no problem. Thats all i now.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- geerbangr
23 Nov 2013 15:45
I think I'm going to move towards a 1327. I'm. Ot looking to ride across the country, just go out at night and bust some asses :evil: :silly: :woohoo:
I wanna build it right the first time so I don't have to go back and do things again later.
1978 KZ 1000
I go by Jason
I go by Jason
- Harvey1327
23 Nov 2013 17:03
I have a 1327 with a 77 head. I guess medium (365) cams, 33 smoothies. It has a copper base gasket and did have a copper head gasket which leaked even after trying different options to stop it. I went back to a stock fibre gasket that came with the kit and and no leaks. I do run 3 breathers, one out of the cam cover and 2 out of the breather cap. The head has been set up for dry block so I'll look at that when I pull down to repair a noisy clutch hub.
I also use a 4 brush starter which came off a gpz. Be sure that your rotor is not loose as the bigger slugs will put more load onto your starter clutch and what I continually experienced shearing the woodruff key
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
- Powerstroke_fan
23 Nov 2013 18:00
the mk11 motors dont have wood ruff keys. But its something to keep in mind.
- geerbangr
24 Nov 2013 12:23
I've not had any luck understanding the overheating issue. What specifically causes the big radical engines to overheat ? How do you know it's overheating other than funny noises or a nuclear meltdown. You guys that run big engines on the street run a temp gauge ? Never saw a KZ with a temp gauge.
1978 KZ 1000
I go by Jason
I go by Jason
- Powerstroke_fan
24 Nov 2013 14:32 - 24 Nov 2013 14:35
Its a air cooled motor. And the bigger size engine you run the more heat it produces. I run a temp guage. It seems like the hottest i saw mine was around 425. But you can smell them when they start getting hot. But heat issues is why most people stay with a low compression ratio. I bought my temp gauge off ebay. its a trail tech brand. It just has a wire that hooks onto a spark plug. You just remove the factory washer on the plug and it goes in its place. I then mounted my gauge on my triple tree handle bar hold down bolts. It just runs off a battery.
Last edit: 24 Nov 2013 14:35 by Powerstroke_fan.
The following user(s) said Thank You: saxjonz
- geerbangr
24 Nov 2013 20:26
So what's a normal stock style 1000 temp usually run ? Then let's say a 1327 temp ?
1978 KZ 1000
I go by Jason
I go by Jason
- Harvey1327
24 Nov 2013 23:54
ran mine on a hot day at a phillip island and couldn't smell anything and had very little in the catch can.
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
25 Nov 2013 18:30
5 pages into this thread and you guys haven't got turbos yet?
1075 turbo, THE street combo.
Cheapest way to 250hp at will that will survive on the street very happily.
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
