Radical streetable engine size
- crh
- Banned
Re: Radical streetable engine size
31 Aug 2013 09:17 - 31 Aug 2013 09:28
That 1327 was converted this past winter to button start because hauling the battery cart around was a pain. It's using an OEM Kaw starter with a good battery. No alternator rotor. Modified starter clutch assembly. Loosing the extra crankcase vent was a concern though so far, no issues.
Cranking pressures are relative to cams and cam timing selected.
Last edit: 31 Aug 2013 09:28 by crh.
- crh
- Banned
31 Aug 2013 09:38 - 31 Aug 2013 09:45geerbangr wrote: So is it better to invest the money in the KZ head because I already own one or get a J head and throw money at it What's the best bang for your buck. How about compression ratio, I don't see many talking about that. Ultra 94 Sunoco gas is about the best pump gas around. Where compression ratio do you start running into detonation issue with the KZ ? How about getting them started ?? Stock starter hold up to a 1327 or a 1428 ?
The 1327 I mentioned had a C&W KZ head on it previously with 36/30 and 8x cams. It ran a best of 6.0 with that head and usually 6.2 - 6.3. The J head was ported by a guy I know and it flows 95. I could fix that to bring it up another 10CFM with no problem.
Can you use your 900 head? Yes you can. Put 38/31 valves in it. Will it be optimal for a 1428? Not in my opinion but that's just me. Others will disagree
If you buy a big block kit from APE with big cams you'll be wanting to keep an eye on your valve springs too. . APE says 75 drag strip passes and it's time to swap them out. I use Kibble Whites for anything over 425 lift.
There are pitfalls to doing what you propose. Do things wrong and you best be prepared for disappointment and money pissed away.
Last edit: 31 Aug 2013 09:45 by crh.
- DFIGPZ
31 Aug 2013 10:47Agreed use a "J" head you will be far ahead of the game Larry check your email.crh wrote:geerbangr wrote: So is it better to invest the money in the KZ head because I already own one or get a J head and throw money at it What's the best bang for your buck. How about compression ratio, I don't see many talking about that. Ultra 94 Sunoco gas is about the best pump gas around. Where compression ratio do you start running into detonation issue with the KZ ? How about getting them started ?? Stock starter hold up to a 1327 or a 1428 ?
1984 750 Turbo
- turboking
31 Aug 2013 11:06
I guess I'm a realist :ohmy: and I know I'm opening a big ole can of worms here :evil: I don't mean to crush anyone's toes.... :lol: but IMO 1075 cc for the street ....no case boring.... big studs all the stuff your told you need to have and do.blah, blah, blah :dry: ......I'm not selling parts or work...... :pinch: make a cool rider kz that you can ride all the time ..... and it may be blasphemy to a lot here but invest your money in newer technology (2nd bike)....... I love old kawasaki z series bikes, cool looking, nostalgic..... but at the same time parts are becoming harder to locate at a decent price.....I already own a 1428 big dry blocked turbo Z ,not ridden much as it gets too hot.... :huh: but if I want fast , I go to another of my street bikes, my pump premium (93 octane) fueled (14 psi boost) 325 h.p dynoed intercooled mcxpress turbo hayabusa. ( best e.t. 8.17 @ 173 in the quarter with 14 psi boost ) there is no comparison between the 1428 Z and the stock bore 1300 hayabusa turbo....... I wish you could out do newer technology , I'm a realist...
and like I said IMO :dry: :side: please, don't shoot the messenger/NO haters....:whistle:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- Powerstroke_fan
31 Aug 2013 12:13 - 31 Aug 2013 12:14
1075 is good. But after i rode mine for a couple years i wanted more power. I love the power from my 1327. It hasnt overheated yet. The hottest its got is 420 F. But My biggest problem is my oil leak and my starter clutch. Larry, Can you tell me a little more about the modified starter clutch? My stock kz starter really struggled to start it before my starter clutch went out. Now it just wings and never engages. I will be buying a honda starter. Iam even running a elctro sport over wound stator and good battery.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 31 Aug 2013 12:14 by Powerstroke_fan.
- geerbangr
01 Sep 2013 07:42
What the deal with the bigger engines leaking oil ?
1978 KZ 1000
I go by Jason
I go by Jason
- DFIGPZ
01 Sep 2013 08:33 - 01 Sep 2013 08:56if put together properly none i have done plenty without issue. when you bore cases for large sleeves it gets thin where studs are installed in cases.geerbangr wrote: What the deal with the bigger engines leaking oil ?
1984 750 Turbo
Last edit: 01 Sep 2013 08:56 by Patton. Reason: delete solicitation
- Powerstroke_fan
01 Sep 2013 09:24
DFIGPZ, Please tell me exactly how you do it so it dont leak. Ive tried two times now and it still leaks. First time i used yamabond. The second time i used gaskanich and annealed the gasket. Both leaked. I cleaned all surfaces very very carefully to remove any old junk. The engine was rebuilt around a 1000 miles ago, everything was inspected and blasted. I retorqued the nuts like stated and neither have held. One idea i did have i thought about trying. You can only buy a copper base gasket for a 1327. I thought about buying a stock fiber base gasket and getting it cut out. I kinda wondered if a fiber base gasket wouldnt work for sealing it up better.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- turboking
01 Sep 2013 15:08
I tried that once ..... I used cinch on it :pinch: squeezed the fiber base gasket out :blink: I tore it back down and replaced it with copper a week later
imo not enough surface area...... :huh: no big stuff on the street z's for me . too many leaks :pinch:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- racer54
01 Sep 2013 20:31
- DFIGPZ
01 Sep 2013 21:38
geerbanger check your pm box.
1984 750 Turbo
- crh
- Banned
02 Sep 2013 09:39 - 02 Sep 2013 09:44turboking wrote: I guess I'm a realist :ohmy: and I know I'm opening a big ole can of worms here :evil: I don't mean to crush anyone's toes.... :lol: but IMO 1075 cc for the street ....no case boring.... big studs all the stuff your told you need to have and do.blah, blah, blah :dry: ......I'm not selling parts or work...... :pinch: make a cool rider kz that you can ride all the time ..... and it may be blasphemy to a lot here but invest your money in newer technology (2nd bike)....... I love old kawasaki z series bikes, cool looking, nostalgic..... but at the same time parts are becoming harder to locate at a decent price.....I already own a 1428 big dry blocked turbo Z ,not ridden much as it gets too hot.... :huh: but if I want fast , I go to another of my street bikes, my pump premium (93 octane) fueled (14 psi boost) 325 h.p dynoed intercooled mcxpress turbo hayabusa. ( best e.t. 8.17 @ 173 in the quarter with 14 psi boost ) there is no comparison between the 1428 Z and the stock bore 1300 hayabusa turbo....... I wish you could out do newer technology , I'm a realist...and like I said IMO :dry: :side: please, don't shoot the messenger/NO haters....:whistle:
Pretty sound reasoning IMO
A dragbike is not a good streetbike but a streetbike can make a hell of a good dragbike. Afterall, it's all in the rider anyway :side:
Last edit: 02 Sep 2013 09:44 by crh.
