Radical streetable engine size
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: Radical streetable engine size
29 Aug 2013 17:16
#603772
I assumed 219 meant MPH... :laugh:
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • crh
  • crh's Avatar
  • Banned
  • Banned
29 Aug 2013 22:03
#603818
Lorcan wrote: I assumed 219 meant MPH... :laugh:
You may be correct but somehow I doubt an old unfaired Z is going to pull 219 MPH. If it does, I'm sure as hell impressed. Come to think of it if it makes 219 HP I'm impressed. Well done either way ;)
  • zukdave
  • zukdave's Avatar
29 Aug 2013 22:38
#603829
219mph on an unfaired KZ would take a
strong son of a bitch just to hang on to it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • geerbangr
  • geerbangr's Avatar Topic Author
30 Aug 2013 05:03 - 30 Aug 2013 05:08
#603888
Anyone running a 1428 on the street ? Also I see over at the kz zone they list a 1425 kit for use with the kz engine and the kz head then they list a 1428 kit for the kz engine with the J model head. What's the difference in the kz head and the J model head and which head is better ?
1978 KZ 1000
I go by Jason
Last edit: 30 Aug 2013 05:08 by geerbangr.
  • crh
  • crh's Avatar
  • Banned
  • Banned
30 Aug 2013 08:04
#603894
The difference is in the piston pin locations. Putting a J head on a KZ bottom end will reduce compression ratio. Therefore that has to be addressed.
J and GPz bathtub heads require less work to make power than a KZ head requires on a large cc motor.
I know an old piece of crap drag bike that will probably spew it's crankshaft all over the track sometime soon that runs 5.70's 1/8 mile steadily with less than .460 lift cams, small tire & bar, anciennt 38 trons, 1327cc, J head with 39/32 combo. The bike is old. The guy has no money....
Excessive heat and/or lack of lubrication are your motor's greatest enemies. Keep that in mind when you build you radical, streetable engine :)
  • geerbangr
30 Aug 2013 13:27
#603925
So is it better to invest the money in the KZ head because I already own one or get a J head and throw money at it What's the best bang for your buck. How about compression ratio, I don't see many talking about that. Ultra 94 Sunoco gas is about the best pump gas around. Where compression ratio do you start running into detonation issue with the KZ ? How about getting them started ?? Stock starter hold up to a 1327 or a 1428 ?
1978 KZ 1000
I go by Jason
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
30 Aug 2013 17:42
#603962
my stock starter would barely handle my 1327. It actually made my sprag unit go out. With a j model head you will lose right around 2 points of compression. If it was me i would get a j model head. But you do have to buy a idler adapter and the jig to locate the holes properly.
1977 KZ 1000 work in progress
  • geerbangr
30 Aug 2013 17:46
#603964
So how did you solve the starter issue powerstroke ?
1978 KZ 1000
I go by Jason
  • racer54
  • racer54's Avatar
30 Aug 2013 20:25
#603994
For the starter, you can use the starter out of a CB1000 Honda. Look for the one that is .8KW. Lots of then are of the .7KW rating. I've heard that a GPZ starter is stronger but I don't know about that one. Lots of racers use a Cashio starter. He rewinds them to be stronger. I think they are for 24V but not sure. You'd have to check that one out to be sure. The popular option is the Honda starter though. Heard it's a bolt in...may need to adjust the cable bolt position though.
  • Hollywoodmx
  • Hollywoodmx's Avatar
30 Aug 2013 23:39
#604043
I posted a thread about doing the same with my GPz vs selling it. I didn't get any replies so I searched further, mostly in drag forums. Apparently the 1428 is not street-able due to not surviving street level heat according to several posts.
Now if there is a 1500 on the road I would love to learn more cause Les is teasing us worse than our 14 year old girlfriend back in JR high.. :ohmy: :P
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
31 Aug 2013 05:11
#604105
The bike is street ridden and really pretty easily but not often. With the time and money in that thing I suspect he doesn't want to waste too much of it's life on needless play. It's a purpose built motor with taking your money being it's main goal. He'll ride it where you want to go just to show you it's not a big bad wolf only to take your goodies. NOT TEASING! it's a serious piece.
Les
  • gpz1170
  • gpz1170's Avatar
31 Aug 2013 08:47
#604112
I know of one 1428 on the street, small cams and lower compression (9 to 1) because of over heating and pump gas. It's ridden ocassionally about 500 miles a year. Impressive when he fires it. Doesn't run bad, either.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
