Valves snapping
- angryeric116
07 Aug 2013 11:03 #600263
by angryeric116
1979 KZ 1000 LTD B3
in the process of restoring.
Weisco 1 to 10.25 pistons
unknown 4 into 1 , pod filters, #122.5 main jets, #15? Idle jets
Valves snapping was created by angryeric116
Hey everyone I am in the middle of restoring my 79 KZ1000 LTD B3. Yesterday my father and I timed the motor, and we noticed that the exhaust valves seem to stick open and "snap" closed when the . The intake valves are not doing the same thing. last night we poured oil over all of the tappets, lobes and just generally all over the cam to let it soak in. I am hoping that good lubrication will resolve the issue, but I wanted to get the forums opinion. Thanks!
Attached is a few pic's off the rolling frame and motor.
1979 KZ 1000 LTD B3
- Thank you received: 797
07 Aug 2013 11:54 #600274
by 531blackbanshee
Replied by 531blackbanshee on topic Valves snapping
was the head rebuilt?
- angryeric116
07 Aug 2013 12:16 #600283
by angryeric116
1979 KZ 1000 LTD B3
Replied by angryeric116 on topic Valves snapping
Yes, the valves were re ground and new oil seals were installed by a reputable shop. I installed some Weisco 10.25:1 pistons myself. The shop did all of the valve work, I gave them the head with the valves still in it, and got it back with them in it.
1979 KZ 1000 LTD B3
07 Aug 2013 13:22 #600289
by 531blackbanshee
makes me wonder if the buckets are sticking in their bores?
maybe remove the cams and see how freely you can slide the buckets up and down.
