- Thank you received: 5
transmission ?
- rlcarter
1980 KZ1000 G w/carbs..
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- rlcarter
- rlcarter
- upncummr
- Thank you received: 16
- rlcarter
- racer54
- Thank you received: 114
- rlcarter
- racer54
- rlcarter
- Thank you received: 797
also pull the cover behind your counter shaft sprocket.make sure the out put shaft bearing is not broken.i had the one in my 1980 z1r crack around the circlip groove and the cage came off letting the bearings"stack"up on one another which allowed enough slack for the output shaft to jump around in first and second.
i have seen another 78 z1r with the same problem.
- Thank you received: 2098
rlcarter wrote: my bike is a KZ1000G it used to have fuel injjection. took it off wanted to change heads to get rid of the injector holes. my 900 frame tag indicates it is a 1976 .the engine no. is Z1E136891 did they make a Z1 in 1976?
Per Zedder:
'76 KZ900-A4
Frame No. Range
Japan MFR Z1F-085701 - 117060
USA MFR Z1F-500001 - 510340
Engine No. Range Z1E086001 - 138846
(includes the Z1E136891 at hand)
1975 was the last year for Z1 model name.
In 1976, became KZ900.
In 1977, became KZ1000.
