cam cap bolthole issues..
- brianrae33
1982 kz1000ltd
- Thank you received: 2098
brianrae33 wrote: had all 16 cam cap boltholes timeserted...well..they didnt take...not sure if ir was shoddy machine work or not..im at my wits end...wondering if anyone has had any experience with loctite thread former????or any other ideas...head has been totally rebuilt so im trying not to give up on it just yet...thanx for any replies...
None of 'em took?
Wonder if any of the other totally rebuilt work took? :ohmy:
- Thank you received: 2829
None of 'em took?
I was wondering the same thing! I don't understand a timesert "not taking" unless the guy used the wrong drill bit or tap when prepping the hole for the insert. Here's how uncomplicated they are to install:
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- Garn
- Thank you received: 13
You may have to seek advice from an expert w.r.t. the methodology and principle of the Timesert.
In an emergency, they do make a 3/8" threaded insert, with a "loctite" strip, with a 6mm internal thread. They also make a "Bigsert". Have a look at the space you have to utilise either.
Before attempting to go bigger, I would see if you can save any of the ones that "didn't take". Remembering you can go deeper for the bolt holes with dowels.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- Dr. Gamma
- Thank you received: 680
Like Garn just said, the cam cap bolts with the dowel pin are a lot harder to do properly.
I have not inserted a cam cap bolt thread with the dowel pin in 12 years, but I kinda remember removing the top lip from the insert because you can't get the Timesert cutter down in the recessed dowel pin hole.
1986 RG500G 2 stroke terror.
- MTH76
If so I had a cam cap that was helicoiled for the correct 6mm bolt that pulled out.
I was told to try a 1/4-28 american threaded helicoil in its place.
Then use the proper length 1/4-28 bolt.
This worked for me.
Good luck,
Mark
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
- turboking
1985 GS 1150E
1983 GS 1100E
- Kraz1
MTH76 wrote: If so I had a cam cap that was helicoiled for the correct 6mm bolt that pulled out.
The rule of thumb is Fine thread 1/4 28 into Steel, and Coarse thread 1/4 20 into Aluminum. There's a ton of info on the internet on the subject, have a look.
Click - - - -> Timeserts
- baldy110
- Thank you received: 512
- aek
art
1980 750-4 LTD original owner
- bluezbike
- Thank you received: 104
79 KZ 1000 LTD
