- Thank you received: 3
I.D this part
- gixxerkidd03
26 Jul 2013 00:52 #598323
by gixxerkidd03
1981 KZ750e
I.D this part was created by gixxerkidd03
so i pulled my oil pan last night because i need to helicoil the drain plug. when i pulled it off i found this in my oil pan. looks like some sort of a guide im not to happy about it because i really dont want to pull the motor and crack the case. :evil: I.D THIS PART!
1981 KZ750e
- gixxerkidd03
26 Jul 2013 00:52 #598324
by gixxerkidd03
1981 KZ750e
Replied by gixxerkidd03 on topic I.D this part
Attachment photo3.JPG not found
Attachment photo4.JPG not found
1981 KZ750e
- gixxerkidd03
26 Jul 2013 00:52 #598325
by gixxerkidd03
1981 KZ750e
Attachment photo5.JPG not found
Attachment photo6.JPG not found
1981 KZ750e
- gixxerkidd03
26 Jul 2013 01:23 #598329
by gixxerkidd03
1981 KZ750e
whoa i didnt mean to post so many, looking to delete the others
1981 KZ750e
- gixxerkidd03
26 Jul 2013 02:31 #598330
by gixxerkidd03
1981 KZ750e
ok i can't seem to delete all my extra post. please someone who had done a tear down on one of these please tell me where that came from, please and thanks kz750E
1981 KZ750e
- KZJOE900
- Admin
26 Jul 2013 03:55 - 26 Jul 2013 03:59 #598334
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic I.D this part
I'm guessing its the front cam chain guide. Did that come out of your oil plug when changing oil?
Buy looking at it closer, I think I'm way off.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 26 Jul 2013 03:59 by KZJOE900.
- tybolt99
- From where KZs came
26 Jul 2013 04:00 #598336
by tybolt99
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
Replied by tybolt99 on topic I.D this part
What model?
Anyway looks like a piece of cam chain guide.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- Mcdroid
- Gone Kwackers
- Thank you received: 317
26 Jul 2013 07:04 - 26 Jul 2013 07:07 #598339
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic I.D this part
Yep...looks like a portion of a cam chain guide. These cam adjusters get brittle with age and sometimes disintegrate. This will entail a top-end tear-down to replace the guides...with the proper tools, not an insurmountable task for you...buy the shop manual (Kawasaki genuine factory manual) if you don't already have it. Since you'll have the cylinder head off...there are a number of other things you ought to be looking at too (cam chain stretch, cylinder bore measurements, replacing valve guide seals, lapping valves, etc.). BTW, all the above can be done with the motor in place
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 26 Jul 2013 07:07 by Mcdroid.
- turboking
- Thank you received: 106
26 Jul 2013 07:24 #598340
by turboking
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Replied by turboking on topic I.D this part
since you did not list model of bike , I'm guessing cam chain tensioner or valve cover cam chain guide ......... :blink: :huh:
1985 GS 1150E
1983 GS 1100E
- roy-b-boy-b
- Thank you received: 103
26 Jul 2013 09:42 #598355
by roy-b-boy-b
Replied by roy-b-boy-b on topic I.D this part
Timing chain guide. You will not have to split the cases.
- gixxerkidd03
26 Jul 2013 12:39 #598392
by gixxerkidd03
1981 KZ750e
damn, it does look like the guide. well here we go. will this require me to just remove the cylinder head or remove the cylinders as well? the guide was found in my pan when i removed it. the modle is a 82 kz750E, a cafe project i was looking to have running is a week or so. very un please at the momment, at least i will be able to run though the engine and make sure all will run smoothly. any other suggestions on what to check out/ replace while i have it all apart? i appericate the help guys!-Eric
1981 KZ750e
- Powerstroke_fan
- Thank you received: 83
26 Jul 2013 14:01 - 26 Jul 2013 14:08 #598399
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic I.D this part
as already stated i would check the cam chain for stretch and the cylinders for wear. I would lap the valves and new valve guide seals. I would check or if it was me id replace all the idlers and rubber guides. If the one is that bad you will probably find more wore rubber parts. It would be a excellent time to make any valve shim adjustments. I would measure before you take it apart, so you know what shims will needed changed out. Also it would be a good time to inspect and if needed replace all rubber parts like carb intake manifold boots, spark plug wires/boots, if money allows, id also go thru the carbs while there off, if you havent already. I know its not in the motor but Be sure to inspect your tires for weather cracking also. Old tires are no joking matter on motorcycles.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 26 Jul 2013 14:08 by Powerstroke_fan.
