- Thank you received: 2829
snapped chain = locked transmission??
15 Jul 2013 21:09 #596662
by 650ed
Did you replace the front and rear sprockets? Ed
Replied by 650ed on topic snapped chain = locked transmission??
syph0r wrote: Well guys.. sorry for the delay in update.. but i got a new o-ring chain and the masterlink is riveted style.......
- syph0r
15 Jul 2013 22:01 #596670
by syph0r
rides:
1982 Kawasaki CSR750
1989 Maxda RX7
1994 Mazda RX7
2004 Ford Ranger
Replied by syph0r on topic snapped chain = locked transmission??
zukdave, Luckily i'm not racing mine. nor did it lock my tires.
650ed, the front is new, the rear is on its way.
I know its not the best idea to put a new chain on an old sprocket, but when you're in a tight spot and your only transportation at the time is the bike... you gotta do what you gotta do to get to work.
Brother (PO) had a new front sprocket. the rear had to order since it has a different rear end on it.
I blame myself for the chain snap tho. I should have replaced it when i pulled it out of storage. 4 years can rust up and stiffen a chain and my common sense knew that. Excitement over a new ride got the best of me. Won't let that happen again.
kzcurt no offense taken, I do know what to look for on a worn sprocket. Had to deal with those on dirtbikes and previous bikes.
rides:
1989 Maxda RX7
1994 Mazda RX7
2004 Ford Ranger
