83 KZ750 Shaft drive. chain rattle
- rboutin2
07 Jul 2013 11:05 #595365
by rboutin2
83 KZ750 Shaft drive. chain rattle was created by rboutin2
zOk, The bike only has 9400 miles on it. Isn't that a low mileage to have chain rattle already? I am in the process of cleaning and syncing the carbs. I am gna check for exhaust leaks as suggested. Now, my question is,what's the correct way to inspect the auto tensioner to make sure it's still working? Can I remove the tensioner without removing the valve cover, pull the plunger in, then reinstall and release the plunger? Also, to check the primary chain for slack, (mostly just for piece of mind) I can just pull the bottom pan off the motor and it will be right there correct?
- Thank you received: 2829
07 Jul 2013 11:14 #595367
by 650ed
Replied by 650ed on topic 83 KZ750 Shaft drive. chain rattle
If the primary chain is making the noise at idle you may just need to synch the carbs. If they are out of sync it will make noise. Ed
- shaftDKZ
- Thank you received: 1
09 Jul 2013 08:41 #595650
by shaftDKZ
Replied by shaftDKZ on topic 83 KZ750 Shaft drive. chain rattle
I had the same problem in my 83 kz550 M1 at 30,000 miles. If the bike sat for any length of time I would say the auto tensioner could use a rebuild or you could just switch to a manual tensioner like I did and save yourself a world of trouble. Those auto tensioners are famous for going bad.
