- Thank you received: 29
Cylinder 4 missing
- Del_Herring
I'm getting ready to send the head in for a complete valve job, and some welding that needs to be done on the exhaust side to fix where the PO overtorqued the exhaust. But before I do, I'm wondering if there are any other things you think might be causing the single cylinder miss. I'd hate to dump all the money on the machine work and parts and still not have a rideable bike.
I've thought about ignition, but it seems like if it was missing spark, there'd be two of them not firing, not sure on that one.
1983 KZ750-N2 Spectre
- Del_Herring
- Motor Head
- Thank you received: 391
- Thank you received: 2098
If not already done, would verify fuel level by performing the clear tube test.Del_Herring wrote: ...Got my float heights set....
- Del_Herring
I'll play with the coils when I get home. Need to get the brakes put back on before I try riding her, so I'm not sure if it's just at idle right now, but I'll try to get her going good enough to get it around the block in the next couple of days.
- moneypit
- Thank you received: 35
2-76 kz900
St Paul MN
- Del_Herring
Took her around the block real quick, and she definitely seemed pretty lean. Had to leave full choke on the whole time, and once it was warmed up, it kept trying to idle high. If I took the choke down at all, it wouldn't take any throttle. Got her up to around 4000 rpms, but didn't get it too high since I don't feel comfortable taking it on the real road in this condition. 4th cylinder may have fired a couple times, there were a couple times when it felt like I suddenly got some extra power without having messed with anything, so it could be an intermittent spark problem.
Picked up some spark plugs/wires/caps yesterday, but they sold me the wrong plugs, and even after I told them I needed non-resistance plug boots, they sold me resistance ones right along-side the resistance plugs. So I'll have to go back and get that fixed on Tuesday.
I'll pull some plugs once the engine's cooled a bit and see if they yield any useful information.
I will get this bike riding properly again.
- ILoveNasacar
- Thank you received: 1
1976 kz750 twin
1976 Ke175
1981 stroked w12 moon lander, autographed by Neil Armstrong, after he was revived by the church of Scientology last month.
- Cynjut
- Thank you received: 26
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- ILoveNasacar
1976 kz750 twin
1976 Ke175
- Del_Herring
I have brand new carb boots from airbox to carb, so those are fine, but maybe the other side. I can try that. My airbox isn't in great condition, so it may be leaky as well. I can test that a little by just blocking it off some and seeing if that helps, shouldn't be too hard. I'll try spraying around the carbs a little too to make sure I'm not seeing any leaks there.
- ILoveNasacar
1976 kz750 twin
1976 Ke175
