Cylinder 4 missing
  • Cynjut
  • Cynjut's Avatar
Re: Cylinder 4 missing
09 Jul 2013 12:43
#595671
I have to add this, if only for completeness:
After brief search, missing cylinder four located on right side of engine next to number three.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
09 Jul 2013 13:24
#595676
Cynjut wrote: I have to add this, if only for completeness:
Yes.
The cylinders are numbered sequentially, beginning with #1 as the first cylinder nearest the shift lever side of the bike, and counting across toward the brake pedal side.
This is referred to as the cylinders being "numbered from left to right" when seated on the bike in normal riding position.
Good Fortune! :)
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
09 Jul 2013 13:57
#595684
Yes.
Good Fortune! :)
Patton, you totally missed it! That was FUNNY! Cylinder 4 missing! HA! :silly: :woohoo:
The following user(s) said Thank You: Cynjut
  • Del_Herring
  • Del_Herring's Avatar Topic Author
09 Jul 2013 15:07
#595708
Yes.
Good Fortune! :)
Nah man, some guy took a saws-all to my engine, and now I don't know where he put the fourth cylinder. :P
1983 KZ750-N2 Spectre
  • Del_Herring
19 Jul 2013 22:31
#597387
Ok, so I had a sneaking suspicion that something might just be off with the valve clearances, and I was all excited that that's what it was going to be. So I checked them today, and they were fine, back to not knowing what's wrong then. I did notice the #3 intake didn't have enough clearance, but that one's actually been running, though maybe a little colder than the first two. 4 was right in the mid range of the spec for intake and exhaust though.
Cyj. I could definitely imagine vacuum leaks being present somewhere. I'll try and grab some hose and just redo some of it Sunday, or tomorrow if it doesn't rain too bad. With regards to spraying to check. I'm used to doing that when it's not running quite right, but when the cylinder isn't firing at all, would that really show anything?
  • Del_Herring
19 Jul 2013 22:42
#597390
I'll try swapping the coils around too. I also have some newer dyna's that I had ordered, but haven't installed yet. Was deciding if I wanted to try swapping them now or later. Both the coils on there now show the right resistance, so I figured they were good. Are there other things that can cause them problems?
