APE Engine
- DesertKZ
Re: APE Engine
30 Jun 2013 23:35
Any ballpark guess the hp numbers?
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- roy-b-boy-b
Re: APE Engine
01 Jul 2013 08:42
No guess on HP. Over a 100 ? :laugh:
- crh
- Banned
Re: APE Engine
01 Jul 2013 09:55roy-b-boy-b wrote: Thanks CRH. It is a cam under bucket but the head is not relieved as much as the 900 dirt drag engine. The bad part is you have to pull the engine to remove the cam covers.
The engine came out of a 79 LTD .
The bike was built to show. It was from Wisconsin I think. It was a bank repo. I have never see a cleaner built bike. The welds are so smooth and blended in that it is amazing.
The bike was bought by a friend of mines Son. He got the bike for less than 10 grand.
I had seen the bike in a shop where I had gone to work on another Kawasaki. They had attempted to get it running good but the owner came and got it and took it to the store where they bought it. They had a fuel pump installed which didn't help any.
I thought the bike was just built for looks being the main goal and not performance. I took some clear fuel line with me and remover the fuel pump after starting the bike and watching the fuel pump out the carbs.
I rerouted the fuel lines like the builder had them over the top of the engine after insulating the fuel line.
It had a Dyna 200 and 2.2 coils. The timing was not set and we set it to a basic timing. and the bike will fire off like a stock bike.
The pistons are low compression.
Did I mention the engine has to be removed to adjust the shim under bucket set up ? :blink:
That's real handy :whistle:
- DesertKZ
Re: APE Engine
01 Jul 2013 10:23roy-b-boy-b wrote: No guess on HP. Over a 100 ? :laugh:
Haha I hope so! :laugh:
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- crh
- Banned
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
Re: APE Engine
02 Jul 2013 01:36 - 02 Jul 2013 01:37
That is a cookie cutter Harley frame modded for a KZ engine.
It's gotta be heavy. If it never ran right I doubt that he knew
that it would have trouble hooking up with that heavy frame.
Just sayin'. Bet it doesn't vibrate and drop parts everywhere it goes!
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Last edit: 02 Jul 2013 01:37 by gearheadmm.
- Powerstroke_fan
Re: APE Engine
02 Jul 2013 21:07
It is a nice bike. I am sure he will get it running good. These big blocks are a blast to drive. But you gotta watch out, Mine likes to either stand up or smoke the 190/19 rear tire. when your really pushing them hard there hard to hang on to. He will be glad its a low compression motor.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
