Idea for pulling dents from header.
- kzz1king
24 Jun 2013 20:40
I bought a solid but dinged up Kerker off of ebay. I have been thinking of having the studs body shops use to pull dents welded on and then heat it and pull on the dents. I have never used this stuff so I dont know if it has a chance of working. Wkat do you think?
Wayne
Wayne
Home built KZ1000 turbo setup
Re: Idea for pulling dents from header.
24 Jun 2013 21:18 - 24 Jun 2013 21:19
Sometimes possible to push an appropriate size ball bearing through a heat-softened pipe to reduce the dent.
Should first weld a cable onto the ball bearing, whereby it may be pulled from inside the pipe.
Pic?
Pic?
Last edit: 24 Jun 2013 21:19 by Patton.
- KZJOE900
- Administrator
Super Users
24 Jun 2013 21:22 - 24 Jun 2013 21:24
I'm not sure welding on a stud and the using a slide hammer would work. I would guess that the thickness is greater on the header than a tank. The difference between a car panel and motorcycle tanks is significant. At least for KZ's, my Yamaha tank is tin foil next to my KZ's. I would try it on junk header first of comparable wall thickness. I saw other members here mention using large steel ball bearings in varying sizes to take out dings. I would they would start off with smaller diameter first and then gradually move up. But I have never seen or read how they use these bearings. Should try finding out.
Edit: Opps, I guess I type and post too slow LOL. Thanks Patton, I have always wondered how they use them.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 24 Jun 2013 21:24 by KZJOE900.
- DesertKZ
24 Jun 2013 21:38
How good are your welding skills? This vid involves major surgery....
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- kzz1king
24 Jun 2013 22:33
I agree that the pipes are heavier. Thats why I was thinking of using the studs with heat applied to the area and then pulling. The bearing thing sounds good but looks to be tough to do.
Wayne
Wayne
KZJOE900 wrote: I'm not sure welding on a stud and the using a slide hammer would work. I would guess that the thickness is greater on the header than a tank. The difference between a car panel and motorcycle tanks is significant. At least for KZ's, my Yamaha tank is tin foil next to my KZ's. I would try it on junk header first of comparable wall thickness. I saw other members here mention using large steel ball bearings in varying sizes to take out dings. I would they would start off with smaller diameter first and then gradually move up. But I have never seen or read how they use these bearings. Should try finding out.
- kzz1king
24 Jun 2013 22:34
The welding I could farm out. I would be more concerned with the pipes warping out of alignment. I guess I could bolt them up to a old head before welding.
Wayne
Wayne
DesertKZ wrote: How good are your welding skills? This vid involves major surgery....
- Kraz1
25 Jun 2013 00:06Please Log in or Create an account to join the conversation.
- kzz1king
25 Jun 2013 14:02
Wow, thanks. That was a read. Another guy whose skills surpass mine greatly! I dod see he used an old head to hold things in place though.
Wayne
Wayne
- Kidkawie
- I bleed premix
25 Jun 2013 14:24
Those plugs can and will pop out.
I do smoker pipes all the time, you should back them up with something.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- kzz1king
25 Jun 2013 20:46
Here are some pics of the pipe I am working on.The air pressure thing looks interesting.
Attachment DSCN2673.JPG not found
Attachment DSCN2674.JPG not found
Attachment DSCN2675.JPG not found
- hawkrider
26 Jun 2013 21:58 - 26 Jun 2013 21:59
There is an easier way, but it requires a large freezer, and depending on the size of the dent, could take several attempts.
When water freezes, it expands about 10%, so this fix relies on this physical property. Fill the dented pipe with water. Wrap the dented area with a rag for insulation. Leave the ends uninsulated. Stick the pipe in the freezer with the dent centered as the lowest point. The ends will freeze and create a plug on each side, and as the water freezes it will build pressure high enough to push the dent out. We use freeze seals in the nuclear industry and depending on the length of the seal, can hold upwards of 3000 psi.
You will want to thaw from the ends first as to prevent creating a vacuum if the middle were to thaw first.
I have done this procedure on a Superhawk header and it worked great. The only sign there was ever any damage was the scratch that was left from the damage.
Greg
1981 KZ750E (Work in progress)
1998 VTR1000F
2004 CBR1000RR
2014 Ninja 650 ABS
1998 VTR1000F
2004 CBR1000RR
2014 Ninja 650 ABS
Last edit: 26 Jun 2013 21:59 by hawkrider.
The following user(s) said Thank You: Del_Herring
- kzz1king
26 Jun 2013 22:55
I think this is the method I will try . I have a big enough freezer and really like the idea and your explanation on the freeze plugs. I assume if I leave the insulation on it will also thaw in the middle last avoiding the vacuum. Thanks.
Wayne
Wayne
hawkrider wrote: There is an easier way, but it requires a large freezer, and depending on the size of the dent, could take several attempts.
