KZ550 crankshaft axial play!?
- accubond
22 Jun 2013 14:07 #593496
by accubond
KZ550 crankshaft axial play!? was created by accubond
Hi,
now my bike is running well. Today i opened up the alternator housing and found that the rotor has play in and out a little bit.
is this ok? it has no radial play, only axial.
Thanks
Thanks
- zed1015
- Thank you received: 1554
22 Jun 2013 16:12 #593506
by zed1015
Replied by zed1015 on topic KZ550 crankshaft axial play!?
Crankshaft end float is normal.
There may be a figure in the Service manual to reference against for abnormal amounts of movement.
You are more likely to have crank bearing wear problems before end float.
If it's running ok leave it alone.
The following user(s) said Thank You: accubond
- loudhvx
- Thank you received: 1616
23 Jun 2013 09:36 #593569
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic KZ550 crankshaft axial play!?
you can grab the manuals from my signature.
1981 KZ550 D1 gpz.
Other links.
