- Thank you received: 229
Head Gasket Anger
- zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- baldy110
- Thank you received: 512
- gpz1170
- Thank you received: 10
Do you put the copper base on dry. I always use Gasket Synch, both sides, have never had one (can't remember any) leak.
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- APE Jay
- Banned
- Thank you received: 58
- steell
APE Jay wrote: Do Not Surface the head if it is warped!!!!
Please expound kind sir
- Old Man Rock
- Thank you received: 225
BTW, try not to get get angry with her for she's 30 years old after all, just part of life building these old beauties back to their previous magnificent glory...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- murr50
- Thank you received: 3
Old Man Rock wrote: Did you use original or new one piece (Gasket maker in the O-ring groove) or two piece head gasket with rubber O-ring...?
It was a new gasket, and I used the two rubber o-rings at each side.
1977 kz650 C
- APE Jay
- Banned
The way these overhead cam cylinder heads are made is from the flat head surface, the cam journals are line bored.
If you remove the head, and it has a warp or bow in it, so does the cam bores. Most I have seen that had slight bow, when reinstalled with good studs, pulls the bow out and the cam bores are straight once again.
We have had cases where the head had signaficant bow, and we put it in the press and bent it back close enough that the studs could handle the rest.
If however, you have the head off the motor and it is bowed or warped, and you surface it flat, the cam bores are now perminately screwed.
We do surface heads, to remove imprefections, raise compression, etc, but never to remove bow or warp.
- bountyhunter
- Thank you received: 337
steell wrote: You can not put RTV on a head gasket and expect it to seal.
Yes, you need a new gasket, and don't use anything on it.
+1 never use RTV on a head gasket. There is some spray on copper adhesive specifically made for head gaskets, but you should not need it with a new gasket if the metal surfaces have been properly cleaned.
Make sure and clean the RTV off completely.
- bountyhunter
My 750 twin came from the factory with very strong sealer on the base gasket. Unbeleivably hard to get the cylinder off, the gasket stayed sealed to both surfaces and tore in half when it separated. I guess they didn't want it to leak.....Powerstroke_fan wrote: Dont feel bad. I just built my motor and got it all together and my base gasket leaks like a mofo.
- Dr. Gamma
- Thank you received: 676
I would be curious what a "signaficant bow" is? 2 thousands across the whole head gasket surface??
4 thousnads??
Do you mount the head in some type of fixture to bend it back close?? Are you using hydraulic pressure of some sort to bend it back?
Are you heating the head up before you attempt this??
You have sparked my curiosity on this one!!! Makes a bunch of sense on what you said about the cam journal alignment though.
1986 RG500G 2 stroke terror.
