- Thank you received: 229
? for Larry.
- zukdave
14 Jun 2013 23:16 #592354
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
? for Larry. was created by zukdave
Total timing in my ign. box is 40 degree's.
I've read 35 degree's bring it all in early
would work better.
would work better.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- steell
15 Jun 2013 00:56 - 15 Jun 2013 00:58 #592367
by steell
Replied by steell on topic ? for Larry.
If you are using the GPZ750 igniter, then many owners reported the GPZ900 ignitor to have a better advance curve, and possibly a rev limiter.
Might give that a try. Story I've read is that most, if not all GPZ UniTrak models igniters will interchange.
GPZ750 FAQ (Google search) has lots of info about such things.
Last edit: 15 Jun 2013 00:58 by steell.
- zukdave
15 Jun 2013 05:55 #592390
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Replied by zukdave on topic ? for Larry.
Steell right now I'm running the '83 GPz750 ign box.
I've got a list of box's that have diff. curve's,
total timing and with or without a rev. limiter.
I'm just thinking 40 degree's is alot of advance.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- crh
- Banned
- Thank you received: 20
15 Jun 2013 07:47 #592396
by crh
Replied by crh on topic ? for Larry.
Easy enough to swap it at the track between passes. There's probably more to be gained by making sure your drive line is as free rolling as you can make it. You're at full advance well below the RPM you're launching at so I don't see how the curve plays into it at all. It's the total advance that matters for what you're doing.
JMO
JMO
- zukdave
15 Jun 2013 10:24 #592406
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I know the curve isn't in play it's the total advance
I was asking about.
Just wondering if taking some timing out would help.
For what the box's sell for I don't want to buy a bunch
that I don't need just to test them even though I know thats
the best way to see what works best.
I was asking about.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Motor Head
- Thank you received: 391
15 Jun 2013 13:15 #592424
by Motor Head
Replied by Motor Head on topic ? for Larry.
Might be worth a Dyno Tune to see where your engine set up will make the best power, with what TA. It may surprise you as to what works the best.
- zukdave
15 Jun 2013 13:44 #592427
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
M/H the pick up plate in my motors fixed I can't move it to change the T/A
all the timing is in the box.
Just looking for some input before I go spend a few
hundred on box's to test what works best.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Motor Head
15 Jun 2013 16:35 #592439
by Motor Head
Mounting holes can be slotted. Stops for the weights can be bent, or material added to limit travel etc. Lot of fine tuning could be done without $ for parts. But to really see the difference, through the curve you really need a Dyno. Money well spent I would think. You can see how the TA is effecting the Torque curve through the useable power range.
- zukdave
15 Jun 2013 18:11 - 15 Jun 2013 18:14 #592451
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
No weights I have a fixed rotor and this is the GPz pick up mount.
Not as simple as slotting a points plate.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 15 Jun 2013 18:14 by zukdave.
- loudhvx
- Thank you received: 1616
15 Jun 2013 18:38 #592455
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic ? for Larry.
The elecronic advance models should increase advance all the way through redline. Quickly at first, then slower as the RPMs go up. So there in not a fixed amount of advance.
1981 KZ550 D1 gpz.
Other links.
- crh
- Banned
15 Jun 2013 18:41 - 15 Jun 2013 18:43 #592456
by crh
Might sound unrealistic but it's possible to tune to make a dyno happy but end up not going as quick or as fast at the track. It happens....
I'd almost be willing to bet that if OMR could get a box in his hands to figure out how the box senses RPM that he might be able to tweak it . Worth a PM anyway. He's pretty darn smart with electronics. He fixed his own CDI for under $10 and a new one cost mega $$$
Another possible solution might lie in the tab on the rotor. You can buy and advanced rotor. That said it seems logical that you might be able to grind one to retard the timing....just a thought
Last edit: 15 Jun 2013 18:43 by crh.
- loudhvx
15 Jun 2013 18:43 - 15 Jun 2013 18:44 #592457
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
Last edit: 15 Jun 2013 18:44 by loudhvx.
