- Thank you received: 2
High RPMS in 5th gear/ kz400?
- recez
- 74 kz400 D
74 kz400 D cafe
- Thank you received: 2829
- recez
- 74 kz400 D
650ed wrote: Sounds like your clutch may be slipping. If you haven't already done so, try adjusting it using the instructions in the Kawasaki Service Manual. Ed
yeah ed.. thats on my to do list for tomorrow. I have a new clutch cable and Friction plates ready to go. I'm a little nervous to do the clutch work.. but I've done everything else might as well keep going, it's worked out so far. Should changing just the friction plates be good enough? or should I replace everything? Really no way to know I guess until I open her up.
thanks ED
74 kz400 D cafe
kzrider.com/forum/10-new-members/580406-...biker-from-mn#580410
- P21
- Thank you received: 34
maybe we can get a ratio here
Kawasaki KZ 1000 Police (2002) P21
- P21
- recez
- 74 kz400 D
650ed wrote: Before opening up the clutch cover try adjusting the clutch using the manual. You may find adjusting it solves the problem and that you don't need to replace the clutch friction plates. If you find it still slips, replacing the friction plates should be enough without replacing the steel plates, but check the steel plates to make sure they're not warped. You may also want to replace the clutch springs - new stock ones will do just fine; no need for heavy duty aftermarket ones. Before you tear into a a clutch job be sure to have the correct tools - especially a torque wrench that is of the correct calibration range for the clutch springs. Have you read the posting regarding JIS screws / screwdriver bits and about JASO-MA oil specs? If not, check this out as it may save you some headaches. Ed
Yeah I have tried adjusting the cable without much luck..It's really old and stiff. I can visual see it fraying at the lever. I have anew one so doing that is a must at this point. I will hold off on the friction plates for a bit I guess. But it has 21k miles and I doubt it has ever been replaced. Thanks for the link!
74 kz400 D cafe
- recez
- 74 kz400 D
P21 wrote: man that would be neat to see kz400 74 i had one i ran the piss out of that thing on highway back and forth to work
Oh man, it's been super fun rebuilding and riding this thing. You wouldn't believe the amount of people that stop and look and say something like you.. ("I had one of those in the 70's.). It's cool. I have to say, I'm really glad my first project was a KZ400 and not a honda CB350 or something. I see the CB's all the time but rarely see a KZ.. Not sure why.
so far as the sprocket count. Would a sprocket with more teeth give me lower RPMs or vice versa? I always get confused on gear ratios.
I have to lean towards Ed's clutch slippage Idea.. I know the clutch is in bad shape. I can rarely find neutral when Idling..and it;s ralmost impossible to shift into neutral or out of first when Idling... the shift shaft just will not move.
74 kz400 D cafe
There's more to adjusting the clutch than just the cable. I'm not specifically familiar with the clutch on the KZ400, but take a look at the manual and I think you will see (if it's like most other KZ models) 3 different places for adjusting the clutch. There should be 2 places on the cable and 1 at the clutch release under the engine cover. If you only adjust the cable you aren't adjusting the clutch push rod, so you may not get full use of the clutch. Ed
- loudhvx
- Thank you received: 1616
www.kz400.com/WorkshopManFrameset-5.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
