- Thank you received: 6
530 conversion on my kz900
- Matteson
KZ 900-a4
- Dr. Gamma
- Thank you received: 680
In 530 I myself would have gone with 39/17 or 2.29, 37/16 or 2.31, 40/17 or 2.35. I had a customer ordered such a small rear sprocket on his Z1 that the sideplates on the chain hit the sprocket carrier!!! When we called Circle Industries after we got the sprocket and the guy at Circle wondered how we were going to get it to fit when they were making it!!!! Bet the 39t or 40t 530 sprocket is close to the same diameter of the stock 630 chain 35t rear sprocket!!
The rear sprocket for a Z1 or KZ900 in 530 is nothing more than 750 H2 triple sprockets!!!
1986 RG500G 2 stroke terror.
- Haybus
- Big Al
- Thank you received: 42
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
- Garn
- Thank you received: 13
To obtain the original gearing ratio (15T/35T). I had no trouble with front 18T and rear 40 or 42T, suits length of chain 110 links.
The only difficulty was finding a locking tab-washer for the front sprocket, as 530 sprocket supplied did not have that small hole for the tab.
It's a great conversion, as the modern chains are stronger than the originals and the drive is a lot smoother!.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- Jeff.Saunders
15 tooth front and 35 tooth rear are stock on the KZ900.
This converts to 18 tooth and 42 tooth 530 sprockets with a 110 link chain.
If you purchased 15 & 33 530 sprockets, they are too small - and you likely have a rear sprocket coming with the wrong bolt hole pattern. Other than custom manufactured, I am not aware of any manufacturer making a 33 tooth 530 sprocket for the Z1/kZ900. That's assuming your rear brake is still a drum brake and previous owners haven't converted to disk on the rear.
With sprockets that small, you'll have issues with the chain slapping the swing arm.
You will need a spacer behind the front sprocket.
What make and series sprockets did you order?
www.z1enterprises.com
Z1 Ent on Facebook,
- Matteson
KZ 900-a4
- Matteson
KZ 900-a4
- Jeff.Saunders
17/38 will work for you, but you still need a spacer.
You will see slightly higher wear on the chain and sprockets by using the smaller sprockets.
Z1 Ent on Facebook,
- Matteson
KZ 900-a4
- Thank you received: 2829
- Jeff.Saunders
Z1 Ent on Facebook,
- Matteson
sprocket ed.650ed wrote: Where is the wobble? Are you marking the wheel or the tire as you turn it? Ed
KZ 900-a4
