Ultimate 83-84 GPz Crank
  • GypZee
  • GypZee's Avatar Topic Author
29 May 2013 11:44
#589723
What would it be? Should I just have my current crank trued and welded or should I consider some sort of hybrid?
Since I already have a Wiseco 1173 kit I suppose I should stick with the 18mm pins. Is there a better option for a lighter crank itself? Maybe use a 900 crank? I know the complete crank/rod/center pin assemblies don't interchange, but what about hybrids?
83 GPz1100
85 GPz550
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Ultimate 83-84 GPz Crank
29 May 2013 11:50
#589724
If you want light and strong with what ever combo possible contact a company like Falicon or Pearson . I have a Falicon crank in my bike now for over 30 years and will let that speak for itself. Don't know Pearson my self , but many here use his shop.
Not looking for a crank debate war . Just 2 references
Dave B) B) B)
  • GypZee
29 May 2013 12:09
#589729
My bike retains the EFI bored-out by Pogue, has a header, and a set of Web-cam 109's. I plan on dropping the 10.5:1 1173 kit in and am considering at least welding the crank while apart that far. Then I thought if I can buy and build a better crank that I can swap-in at the time that would be even better than waiting for the crank to be done.
It's not a blown, nitrous, or anything else really wild, but thought if I were to buy a crank, why not look at making an improvement If it can be done within a reasonable budget?
83 GPz1100
85 GPz550
  • crh
  • crh's Avatar
  • Banned
  • Banned
29 May 2013 13:44
#589741
Just send it to Pearson for a thrust bearing, true & weld. They were prone to thrust bearings going bad. John will inspect the whole crank and tell you if anything else is failing. The Pogue throttle bodies were a good choice.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
29 May 2013 21:49
#589824
Gotta agree i would send it to Pearson Racing. John does excellent work. He did my crank and trans and the jugs.
1977 KZ 1000 work in progress
  • Dr. Gamma
  • Dr. Gamma's Avatar
29 May 2013 22:04
#589828
This Pearson Racing, do they have a website?? All I find is some Pearson guy that does Gold Star cranks.
Last place I sent a motorcycle crank to was Marine Crankshaft out in California. Nice work!!!
1986 RG500G 2 stroke terror.
