- Thank you received: 797
Good times! Cam chain destruction
03 Jun 2013 11:46 #590637
by 531blackbanshee
Replied by 531blackbanshee on topic Questions on good times! Cam chain destruction
don't use grease on the pistons for assembly.
use engine assembly lube.
or the same oil that you plan to run in the engine.
The following user(s) said Thank You: 771000LTD
- bluezbike
- Thank you received: 104
03 Jun 2013 15:07 #590667
by bluezbike
79 KZ 1000 LTD
Replied by bluezbike on topic Questions on good times! Cam chain destruction
+1 on what crh said. You must use the cam caps from the head they were originally from as cam caps and head are line bored and are not interchangeable, also if you are going to use the better cam bearings swap them over in the same positions they are in now. I am still a little confused by the cam chain issue you posted. If you have an endless chain I believe you should not split the chain and add a rivet link...others more knowledgeable will chime in here but I think you have to split the cases (a much bigger job) to install an endless chain. Also very important..... do you have a factory service manual for your bike? This would be a crucial thing to have to do the work you have planned. Good luck man
79 KZ 1000 LTD
- 771000LTD
03 Jun 2013 22:16 #590730
by 771000LTD
Replied by 771000LTD on topic Questions on good times! Cam chain destruction
Sorry for any. Confusion, I did break the chain and use the rivet link. Did not want to split the cases, No time and (Afeardid)
thanks,Stephen.
Goning to post pics but can't from this touch pad.Need to get to a lap top. WILL BE WORTH THE WAIT!!!!!!
Thanks to all,
Stephen
(build day Wed the 5th). Weeeeeeeeeeeeeee
thanks,Stephen.
Thanks to all,
Stephen
04 Jun 2013 09:46 #590790
by 531blackbanshee
i have used rivet links several times on these motors.
back when i was young,broke and didn't wanna split the cases. :whistle:
because i was afraid something would shoot out and i would never find it :laugh: .
as long as you installed it properly you prolly won't have any trouble with it.
- 771000LTD
08 Jun 2013 06:33 - 08 Jun 2013 06:36 #591302
by 771000LTD
Replied by 771000LTD on topic Good times! Cam chain destruction
:woohoo: well it runs...for now. Haven't done anything else other than turn it over and here it purr for a few minutes!!!! (sounds very tight, in a good way)
Had 100psi in all 4 after assembly but before actually running it.
Lots left to do. Was reading past threads about breaking it in. The only true new stuff were the rings and cam chain. Its been 30 years since I had a bike where I had to baby it. Going to take it slow.
Once again, thanks to all who contributed to this point!!!!
Still trying to get pics up.
Stephen
(the rain didn't help-east coast- and my wifes name is Andrea also.....sign? NAAAAAAAH
Stephen
Last edit: 08 Jun 2013 06:36 by 771000LTD. Reason: adding word
- 771000LTD
19 Jun 2013 20:05 #593129
by 771000LTD
:ohmy: Well i will start the destruction pictures. Lesson to any body that may think they hear sumthin funny coming from the head....better to take a look,that may only be the cost of a valve cover gasket!
- MDawnz1
- Thank you received: 27
20 Jun 2013 01:33 #593164
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic Good times! Cam chain destruction
OUCH !!!!!!!
Now that is just a suckin way to start the summer.
1974 Z1a, still 903
- 771000LTD
20 Jun 2013 18:45 - 20 Jun 2013 18:47 #593256
by 771000LTD
Well....here it is
Last edit: 20 Jun 2013 18:47 by 771000LTD. Reason: pictures didn't upload
- 771000LTD
20 Jun 2013 19:02 #593259
by 771000LTD
Lets try again
- 771000LTD
20 Jun 2013 19:07 #593261
by 771000LTD
Trying again
- 771000LTD
21 Jun 2013 09:27 #593347
by 771000LTD
Trying again to upload
- 771000LTD
21 Jun 2013 09:38 #593348
by 771000LTD
Last ones
