Good times! Cam chain destruction
- 771000LTD
Question..can you put the jugs from a 1979 shaft on a 1977 engine(and have it run,I mean I know you can,but can you) I will be using the 77 head with stock cams and chain
PLEASE tell me I can,its been a bad bad bad week
Thanks to all and to all a good night! :ohmy:
- Thank you received: 797
straight swap.
- 771000LTD
Thanks ,much needed GOOD news :woohoo:
Stephen
you might have to use the cams that go with the bottom end as the shafty motor has a good chance of being a mk11 engine with different amount of sprocket teeth.
take pics.
post them here :evil: !
- 771000LTD
I will post pics cause the head damage is impressive. Maby just for me cause I'm a cherry. :dry:
Thanks Leon
- APE Jay
- Banned
- Thank you received: 58
771000LTD wrote: Bought a heavy duty cam chain and rivet link.(tsuekai)?
Thanks Leon
You either biought a heavy duty cam chain, or one with a rivet link. It can't be both.
- 771000LTD
- Thank you received: 2098
• Heavy duty Tsubaki linked cam chains, requiring Tsubaki BS05MH Master Link;
• Extra heavy duty Tsubaki endless cam chains.
Opinions vary as to choosing between ease of installation with risk of potential link failure, or splitting the cases to install an endless cam chain.
771000LTD wrote: Hey there, I was just going to use the jugs from the 79 and a 78 head with stock cams.Bought a heavy duty cam chain and rivet link.(tsuekai)? Also going to re-ring the pistons from that 79 shaft and use those also and basically all the cam chain sprockets. Are those the ones your talking about.
Thanks Leon
the cam sprockets are the ones i was referring to.
the gear in the center of the crank and the sprockets on the cams are the ones that need to be matching.
heads and cylinders swap no sweat.
all the idler gears are interchangeable,just look em over and use the best ones.
- 771000LTD
Thanks,Stephen
- 771000LTD
1.going to start reassembling engine(top end).Should I be use some sort of greese on sleaves, pistons etc ?
2.Using the 79 st jugs which turned out to have been upgraded to .50 oversize. (0.020)? Any problem with using normal 77 head gasket.
3. Bought a head of e-bay (1978) and in came with bearings and caps. Since I'm using the cams from the 77 head should I also use the the bearings and caps from the 77 also ?
Thanks in advance,
stephen
- crh
- Banned
771000LTD wrote: Hello everyone,
Thanks in advance,
stephen
You can use the bearings if they're in better shape but use the caps from the new head.
