what oil is best for kz900
- stunter956
1976 kz900 "mean green"
- Matteson
- Thank you received: 6
KZ 900-a4
- roy-b-boy-b
- Thank you received: 103
Should take you a month to read it.
- Thank you received: 2829
Using oils that are not designated as meeting the JASO-MA standard may be destructive to KZ clutches. Here's a link that may be helpful:
www.oilspecifications.org/jaso.php
- bountyhunter
- Thank you received: 337
10-40. Don't use any oil that says "energy conserving" on the label. I do add ZDDP to mine since new oils don't have enough.stunter956 wrote: Wat oil do u guys reccomend for my kz900? Ive heard some oils make clutches slip.
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
jeffasaki wrote: kawasaki 40w mineral oil
??? That's mighty thick stuff to try to pump through a cold engine on startup. That's why they make (and recommend) 10W40. Ed
- Thank you received: 1656
- zed1015
- Thank you received: 1554
Made for roller bearing cranks.
Use it in all my big zeds.
Good stuff.
- stunter956
- zukdave
- Thank you received: 229
Rotella T 10w40.
Don't add chit to it fix the real issue
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Hollywoodmx
zed1015 wrote: Rock oil TRM 20/60.
Good stuff.
We don't have that here unfortunately. What do the rotex's like?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
