what oil is best for kz900
- stunter956
13 May 2013 19:28
Wat oil do u guys reccomend for my kz900? Ive heard some oils make clutches slip.
1976 kz900 "mean green"
- Matteson
Re: what oil is best for kz900
13 May 2013 19:45
Any JASO oils. They should say it on the bottle. M-Folks should chime in any time now... He is pretty knowledgable about that stuff.
KZ 900-a4
- roy-b-boy-b
13 May 2013 20:30
Please use search as this is probably the most over discussed thread there is.
Should take you a month to read it.
13 May 2013 20:50
The ingredients in oils have changed over the years. Automobile oil is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early automobile oils contained zinc phosphorus compounds (ZDDP) to protect engines from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in automobile oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal automobile engines. However, today's automobile oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
Using oils that are not designated as meeting the JASO-MA standard may be destructive to KZ clutches. Here's a link that may be helpful:
www.oilspecifications.org/jaso.php
- bountyhunter
14 May 2013 01:20 - 14 May 2013 01:2210-40. Don't use any oil that says "energy conserving" on the label. I do add ZDDP to mine since new oils don't have enough.stunter956 wrote: Wat oil do u guys reccomend for my kz900? Ive heard some oils make clutches slip.
Last edit: 14 May 2013 01:22 by bountyhunter.
- jeffasaki
14 May 2013 01:24
kawasaki 40w mineral oil
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
14 May 2013 08:54jeffasaki wrote: kawasaki 40w mineral oil
??? That's mighty thick stuff to try to pump through a cold engine on startup. That's why they make (and recommend) 10W40.
14 May 2013 11:40
Shell Rotella-T 15W-40 regular in the white bottle now has the JASO-MA rating. It's a heavy duty oil marketed for diesel engine use, but is suitable for motorcycles, but it may not be suitable for cool/cold weather, particularly at startup. A side benefit is that it's typically cheaper than other oils. Chevron Delo & Valvoline Premium Blue are a couple of other heavy duty oils. Nowadays, though, you have to read up on any formulation changes - I read somewhere that they're even starting to change the anti-wear ingredients in the heavy duty oils.
- zed1015
14 May 2013 12:00
Rock oil TRM 20/60.
Made for roller bearing cranks.
Use it in all my big zeds.
Good stuff.
Good stuff.
- stunter956
18 May 2013 14:21
Good advice guys thanx how does a little bit of lucas treatment oil and the rest with rotella sound? Too much thickness? Im quite sure my valve seals are wearing out so i think i will need oil treatment. I live in tip of south texas so cold weather isnt a problem. I will change out my seals soon but i want a quick fix for now
- zukdave
18 May 2013 21:42 - 18 May 2013 22:01
Stunter I'm in Austin so about the same temp's and run the
Rotella T 10w40.
Don't add chit to it fix the real issue
Rotella T 10w40.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 18 May 2013 22:01 by zukdave.
- Hollywoodmx
19 May 2013 11:52zed1015 wrote: Rock oil TRM 20/60.
Good stuff.
We don't have that here unfortunately. What do the rotex's like?
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
