1980 kz1000G1
05 May 2013 15:46 #585798 by rlcarter
1980 kz1000G1 was created by rlcarter
i have a 1980 kz1000G1 fuel injected i was told i could take the fuel injection off and go to carbuators i have done this and cant get it to start it has spark but will not fire is there something else i need to do
1980 KZ1000 G w/carbs..
05 May 2013 16:15 #585801 by MFolks
Replied by MFolks on topic 1980 kz1000G1
What type of carb did you install in the place of the FI?
05 May 2013 16:47 #585803 by rlcarter
Replied by rlcarter on topic 1980 kz1000G1
MIKUNI off of a 1976 900
05 May 2013 16:58 #585804 by MFolks
Good fuel flow to the carbs? You don't have a vacuum operated petcock on the tank? I'd drop one or more float bowls & turn on the fuel to see if there's a blockage.
05 May 2013 17:17 #585809 by rlcarter
the carbs are getting fuel. could it be the difference in the heads where the injection mounted it has the carbs about an inch further away from the heads could that cause it to not pull the fuel into the cylinders.
05 May 2013 18:00 #585815 by MFolks
Have you done a compression and leak down test? A new/rebuilt engine might have 180-200 PSI, put some years & miles on it, and the compression might be 160 or so. An engine will run at 100 PSI, but burn more fuel, and produce low power. Checked the valve clearances too?
05 May 2013 18:30 #585819 by rlcarter
have not done a compression check yet but this bike has ran recently with the fuel injection on it what did you think about the difference of distance away from the heads the carbs are mounted because they were made for injectors .
05 May 2013 18:30 #585820 by roy-b-boy-b
Replied by roy-b-boy-b on topic 1980 kz1000G1
You did plug the injector holes or left the injectors in place?
05 May 2013 21:42 #585855 by rlcarter
yes i have plugged the holes
05 May 2013 23:01 #585874 by kzz1king
Replied by kzz1king on topic 1980 kz1000G1
I ran a fuely head for a long time with carbs with no issues,ran great.
Wayne
Home built KZ1000 turbo setup
05 May 2013 23:28 - 05 May 2013 23:30 #585880 by Patton
Replied by Patton on topic 1980 kz1000G1
Perhaps the carb pilot circuits need cleaning, and maybe the enrichener (choke) circuit also.
Immediately after failure to start, do the spark plug tips have fuel on them?
Good Fortune! :)
Last edit: 05 May 2013 23:30 by Patton.
06 May 2013 16:43 #586006 by fitscott
Replied by fitscott on topic 1980 kz1000G1
I have a 1980 G1 and it ran fine with VM 26s. The extra length intakes didn't seem to cause any problems Good luck, Scott
