fuel gauge???
- drummerjoe10
Re: fuel gauge???
02 May 2013 00:03
thqnks Mullineaux, for some reason i didnt think about that lol n who knows ed, power windows and power steering could be next! LOL :laugh:
- drummerjoe10
Re: fuel gauge???
02 May 2013 00:04
and thanks for all the input here guys, lots of helpful stuff
- TomW
- Keep the blue side up.
Re: fuel gauge???
02 May 2013 01:39 - 02 May 2013 01:41Airplanes have had fuel gauges like that since about the Wright Bros. time. The tank was just in front of the instrument panel and the sight tube was on the panel. The fancy ones had some crude graduations and a little colored ball that floated on the gas in the tube. Just what you wanted in the cockpit, a potentially leaky sight tube and a fuel tank that gets to the crash a split second before you do. :woohoo:Mullineaux wrote: You could make a fuel sight. Basically weld two bungs on the side of the tank, usually one low towards the rear and one high towards the front. Attach right angle fittings to the bungs pointed at each other and connect them with clear (fuel compatible) tubing. You'll be able to see the fuel level in the tube. Google image search "chopper fuel tube" to see a pic if my description is a little hard to visualize.
edit: added a pic
Attachment 453910951_tp.jpg not found
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Last edit: 02 May 2013 01:41 by TomW.
Re: fuel gauge???
02 May 2013 01:47One didn't. :lol:slayer61 wrote:Patton wrote: It's a good habit to reset the odometer back to zero when refilling the fuel tank.
Most often reach reserve level at pretty close to the same mileage each time.
But usually just re-fill before getting to the reserve level.
Isn't that the way we ALL did it before fuel gages on bikes became popular or common?
