stripped spark plug hole...
  • apbling
  • apbling's Avatar Topic Author
30 Apr 2013 16:52
#584969
So, it's not a Kawasaki, but I manage to have a Honda 350 with a stripped spark plug hole.
I REALLY don't want to pull the head, mainly because it's not my bike and I'm reviving it for a friend. Aside from finding a new head off ebay or something, what are my options?
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
Re: stripped spark plug hole...
30 Apr 2013 16:55
#584970
Put in an insert. Use lots of grease on the tap. The cuttings will stick to the grease.
1982 Kawasaki KZ550 LTD
30 Apr 2013 17:31
#584974
The initial threads may be cross-threaded (often resulting from some earlier ham-fisted plug installation) making it impossible to get a plug properly started into the hole.
Often, there's a lot of good undamaged thread remaining deeper inside the hole past the shallower cross-threaded area.
The challenge then becomes how to perfectly re-thread the shallow cross-threads to sync perfectly with the deeper good section.
It may be possible to re-cut the cross-threads by starting at the deep end with a reverse tap, also known as a back tap.
The reverse tap inserts all the way through the spark plug hole, and then the tool's deep end expands to begin tracking along the good threads from the deep end, and re-cuts the cross-threaded section as the tool proceeds upward and out of the hole.
It's akin to having the head off, and re-threading the hole in the normal manner starting with the good threads on the piston side of the plug hole.
A reverse tap accomplishes the same result, but without needing to remove the head.
Here's a pic of the reverse threading tool.
Good Fortune! :)
The following user(s) said Thank You: dejavoodo41, kzz1king
  • kzz1king
  • kzz1king's Avatar
30 Apr 2013 18:56
#584987
Thanks Patton, I never knew what a back tap was or what it was for. A good tool to have in the arsenal.
Wayne
Home built KZ1000 turbo setup
  • apbling
09 May 2013 11:12
#586563
OK guys, thanks for your help. Tried to get motor out of frame, but someone welded the shifter on, hence can't take the sprocket cover off, hence no motor out of frame, hence no head off motor to do this job, therefor, pissed off Andy. It's all back together now and I'll grease the tap up and use air while drilling/tapping to blow shavings out.
The real question...I have a steel timesert...Can I use it, or should I get an aluminum one?
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 May 2013 11:42
#586566
I've used those repair/insert kits before with good results.
whatever you do, bring that cylinder up to TDC and lock it there. In case anything falls in and so you can vacuum out any debris.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • apbling
09 May 2013 12:07
#586571
Kidkawie,
I agree. I think my plan was to have it positioned just a hair after the intake stroke, that way the intake valve is opened, but not full open. The piston would be slightly lower too (that way I don't hit piston or valve with bit or tap). I planned on having my shop vac or aircompressor blowing air into the intake and hopefully out the spark plug hole as I drill and tap. Afterwards I planned to slowly rotate back to TDC and vacuum out any remaining debris. I also planned on greasing up the tap so the shavings stick to it.
What about the steel insert in the aluminum head? that ok?
09 May 2013 12:56 - 09 May 2013 12:59
#586580
apbling wrote: ...Tried to get motor out of frame, but someone welded the shifter on, hence can't take the sprocket cover off, hence no motor out of frame, hence no head off motor to do this job...The real question...I have a steel timesert...Can I use it, or should I get an aluminum one?
Engine head may be readily removed with engine remaining in the frame.
Where a timesert is needed to replace and serve as threads in an aluminum engine, would use a timesert made of steel. I didn't know timeserts constructed of aluminum were available.
Good Fortune! :)
Last edit: 09 May 2013 12:59 by Patton.
  • mattb
  • mattb's Avatar
09 May 2013 13:01
#586581
I did this on my KZ1000 several years ago. Used a shopvac to suck up shavings as the tapping took place, plus sucked everything out of the cylinder. Fortunately my dad (a professional mechanic) has a cool little fiber optic scope that let us look around inside the cylinder and on top of the piston to make sure we got everything out.
It has been in for many years and many miles, with plugs going in and out and I have had no issues with it.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 May 2013 13:03
#586582
apbling wrote: What about the steel insert in the aluminum head? that ok?
No prob, spark plugs are steel. You need to locktite the insert in place.
1975 Z1 900
2004 KX125
  • apbling
09 May 2013 13:05
#586584
excellent, sounds great and I have all my tools. I have access to a little camera scope, but it's a little big to fit in the hole...
Yes, blue loctite was in my plans.
Patton - Head cannot be removed. It's a 73 Honda CL 350 and the studs run from the case, through the jugs and cam cover. All that can be removed in frame is the cam cover. :(
09 May 2013 19:22 - 09 May 2013 19:38
#586622
apbling wrote: ...Patton - Head cannot be removed. It's a 73 Honda CL 350 and the studs run from the case, through the jugs and cam cover. All that can be removed in frame is the cam cover. :(
Thanks, apbling! :cheer:
Should have remembered that. :ohmy:
If needed, here's a link that provides a free downloadable Factory Shop Manual.
www.mediafire.com/?5f3menxnmzm
Good Fortune! :)
Last edit: 09 May 2013 19:38 by Patton.
