I found a crack in my exhaust =[
- magruder13
29 Apr 2013 20:43 - 29 Apr 2013 20:44
I've got a '77 KZ 750 that I just picked up, had a really rusted exhaust, so I started hitting it with a wire grinder to get down to bare metal to paint it. While cleaning it up near the heads I found this:
I know a guy that's been welding for some 30+ years and I'm going to see if he can fill it in with a TIG. I'm just worried about it not coming out clean enough and having trouble getting the collars back in there.
1982 Honda XL125S
1972 Yamaha TX750 (CB750 engine)
1976 Kawasaki KZ400
1976 Kawasaki KZ400
Last edit: 29 Apr 2013 20:44 by magruder13.
Re: I found a crack in my exhaust =[
30 Apr 2013 12:04Please Log in or Create an account to join the conversation.
- TomW
- Keep the blue side up.
30 Apr 2013 12:56Get it good and clean and weld it up from the inside. Then a pass with no filler on the outside to fuse the crack at the root. Your weldor friend probably knows this. Oh, and be sure to remove that gasket.magruder13 wrote: I've got a '77 KZ 750 that I just picked up, had a really rusted exhaust, so I started hitting it with a wire grinder to get down to bare metal to paint it. While cleaning it up near the heads I found this:
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
- magruder13
30 Apr 2013 20:01
Martin: Thanks for that, I couldn't get it to work for some reason!
Tomw: That's actually not the gasket on the end. The pipe is two layers thick and only the outside one cracked. If you look at the picture, you can see about a half inch down the tube where the inner pipe and outer are spot welded together.
1982 Honda XL125S
1976 Kawasaki KZ400
1976 Kawasaki KZ400
- Powerstroke_fan
30 Apr 2013 20:33
I had a kerker header that did the same thing but it burnt thru both layers before i realized it. I found a guy that said he has a jig he made for repairing the ends.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- magruder13
01 May 2013 00:49Powerstroke_fan wrote: I had a kerker header that did the same thing but it burnt thru both layers before i realized it. I found a guy that said he has a jig he made for repairing the ends.
I honestly only realized it since I ground down through a VERY thick layer of rust. Glad I did, pipes are looking good now, just need to fix the bike so I can paint the exhaust and "bake" the paint on.
1982 Honda XL125S
1976 Kawasaki KZ400
1976 Kawasaki KZ400
- TomW
02 May 2013 01:48I wondered about those spots. So how did the flange separate from the pipe? IOW why didn't the inner flange hold it together?magruder13 wrote: Martin: Thanks for that, I couldn't get it to work for some reason!
02 May 2013 03:14 - 02 May 2013 03:25
The clamp and split collars press only against the flange. The pipe is otherwise free to pull out and away through the split collars and clamp (and will readily do so without the flange).
Think of it as if the flange was glued to the end of the header pipe instead of being welded, and the header otherwise installed normally. It would be relatively easy to pull the pipe free by breaking the glue bond. While the flange itself will remain held tightly in position by the clamp and split collars.
Last edit: 02 May 2013 03:25 by Patton.
- TomW
03 May 2013 13:39Patton wrote: The clamp and split collars press only against the flange. The pipe is otherwise free to pull out and away through the split collars and clamp (and will readily do so without the flange).
I know how the pipe is held on to the head. I've R&R'd them numerous times. It's apparent then that the spot or rosette welds holding the inner pipe to the outer are not all holding.
