Vacuum leak?
- Kapahulu
Re: Vacuum leak?
30 Apr 2013 04:56The general jetting recommendation I've seen on this forum for stock mikuni's with pods is 20 pilot 120 main. I saw this old Hot Bike Engineering jetting guide on the Kawi Triples resource website and it shows 117.5 - 120 mains for KZ900's and 1000's. I think this supports what Dr. Gamma is saying.Dr. Gamma wrote: If you have good compression, a Kerker Copm baffle, clean K&N or Unifilter individual filters on true 1976 KZ900 carbs try running 117.5 or 120 REAL Mikuni brand main jets...
Also I am finding that my KZ900 with pipe and stock airbox/K&N filter is running rich with 120's and I think I'll get some 117.5's.
2strokeworld.com
2strokeworld.com
- Matteson
Re: Vacuum leak?
30 Apr 2013 07:58
I'll give those a try. Every time I put new plugs in it runs way better for a while. Although when I'm at a light and start off it almost dies then I push through it. Timing?
KZ 900-a4
Re: Vacuum leak?
30 Apr 2013 09:34 - 30 Apr 2013 23:36Among the suspects would be imperfect carburetion, or maybe a sticking advancer.Matteson wrote: I'll give those a try. Every time I put new plugs in it runs way better for a while. Although when I'm at a light and start off it almost dies then I push through it. Timing?
Proper carb sync might also help produce a stronger pull-away from idle.
Last edit: 30 Apr 2013 23:36 by Patton.
- Z1Driver
- love the smell of triple smoke
Re: Vacuum leak?
30 Apr 2013 12:45 - 30 Apr 2013 12:53
I would also check for corrosion on the wire ends which screw into the spark plug boots.
But it sounds like carb holders are in order first thing.
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 30 Apr 2013 12:53 by Z1Driver.
- Matteson
Re: Vacuum leak?
30 Apr 2013 23:30
120's are in the mail. I will put new fuel lines with new filters too. She rode strong today. A little air screw adjustment went a long way too. I'm afraid to put 120's in if it runs fine with 125's.
KZ 900-a4
- Cope
Re: Vacuum leak?
02 May 2013 19:08
You mentioned you cut off the rear foot braces 10 months ago. Did you keep the pieces I need a left hand one.
- Matteson
- Cope
- Matteson
Re: Vacuum leak?
03 May 2013 15:09
No braces cut off mine. I like to throw my legs on the passenger pegs when I rocket down the highway at 120. I cut the mounts for the blinkers off and got rid of the fender and made a custom light and license bracket.
KZ 900-a4
- jonarmstrong
Re: Vacuum leak?
03 May 2013 17:47. I have a couple extra sets. Pm me if you need emCope wrote: You mentioned you cut off the rear foot braces 10 months ago. Did you keep the pieces I need a left hand one.
82 Kz1000 gpz1100 cams dyna ignition kerker k&n
- Cope
Re: Vacuum leak?
06 May 2013 15:56
Yes I need a left hand one. When I replaced the 4 into 1 exhust had to cut off just below the footpeg and now want to restore. My e-mail is:
[email protected]
[email protected]
