HELP!!!!
- kenfowler123
HELP!!!!
26 Apr 2013 18:33
OK, now i am getting frustrated. I changed the stator gasket due to the fact that it was leaking oil. Ordered an aftermarket one off ebay, installed it and it still leaked. Then I took it back apart and added gasket sealer to the gasket and waited 24 hours but it still leaks. The leak is coming out where the rubber piece holds the wires in place towards the bottom of the cover. The only thing I can think of is to order 2 gaskets and install? HELP!!!!!
1982 KAWASAKI KZ 1100 A SHAFT
Re: HELP!!!!
26 Apr 2013 18:38
Please add your bike's year and model to your signature line. Ed
- gengomerpyle
Re: HELP!!!!
26 Apr 2013 18:46
is the stator cover cracked?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
Last edit: 26 Apr 2013 18:53 by Patton.
Re: HELP!!!!
26 Apr 2013 18:55
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
- KZJOE900
- Administrator
Super Users
Re: HELP!!!!
26 Apr 2013 19:19 - 26 Apr 2013 19:22
Your stator cover rubber grommet is probably hard as rock by now if its never been changed. New ones are soft and pliable. Changed mine 6 months ago. Big PITA! But I was replacing the pealing chrome stator cover with a nice polished aluminum replacement anyway. Requires that you cut the wire to replace the grommet. Then solder back on making sure I had heat shrink tubing to cover up everything nicely. I don't think I used anything on the grommet itself but used some RTV sealer around the edges of the heat shrink to keep any moisture away from my solder splices. I just used a standard paper gasket for the cover but sprayed it with Permatex Copper gasket spray just for kicks.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 26 Apr 2013 19:22 by KZJOE900.
- daveo
Re: HELP!!!!
26 Apr 2013 20:07 - 26 Apr 2013 20:26
You need to apply sealer to the area where the wires pass through, well as the groove around the edge of the rubber. After assembly, let it cure for six months before starting the engine. That should be sufficient time.
Sorry to say it, but this is a fussy repair to get right
I use only OEM, Genuine Kawasaki gaskets and O-rings, if possible.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 26 Apr 2013 20:26 by daveo.
- zukdave
Re: HELP!!!!
26 Apr 2013 20:20
Not sure what motor you have but my GPz750 motor
does not have an oil bath stator.
You may what to look at the crank seal letting oil passed.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Dragone
Re: HELP!!!!
28 Apr 2013 06:52zukdave wrote: Not sure what motor you have but my GPz750 motor
That is my thinking as well on this. The grommet is to keep the wires from chaffing and to keep dirt out, not oil in.
- kzz1king
Re: HELP!!!!
28 Apr 2013 09:52
That is my thinking as well on this. The grommet is to keep the wires from chaffing and to keep dirt out, not oil in.[/quote]
Depends on what model he has. Unless I missed it he didn't say.
Wayne
Wayne
Home built KZ1000 turbo setup
- kenfowler123
- LarryC
Re: HELP!!!!
28 Apr 2013 10:54KZJOE900 wrote: Your stator cover rubber grommet is probably hard as rock by now if its never been changed. New ones are soft and pliable. Changed mine 6 months ago. Big PITA! But I was replacing the pealing chrome stator cover with a nice polished aluminum replacement anyway. Requires that you cut the wire to replace the grommet. Then solder back on making sure I had heat shrink tubing to cover up everything nicely. I don't think I used anything on the grommet itself but used some RTV sealer around the edges of the heat shrink to keep any moisture away from my solder splices. I just used a standard paper gasket for the cover but sprayed it with Permatex Copper gasket spray just for kicks.
x2 on the grommet
Larry C.
