- Thank you received: 104
Norris Cams...any info?
- bluezbike
79 KZ 1000 LTD
- Garn
- Thank you received: 13
The significants of the engraving "440-SC" I don't know.
The best thing to do is measure the standard inlet cam from the tip to the base circle.
For example the standard Z1 cam measures 36.2 mm,
Whereas, my Norris came measures 37.5 mm.
Meaning that the Norris gives an extra 1.3 mm lift.
Too much lift is not good for street use.
Of course, there are other dimensions of the cam the ramp & dwell.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- Motor Head
- Thank you received: 391
I always liked the Norris Cams in the old VW motors, they were great. I would think that they are good Cams. Might be a lot for a street motor, depending on displacement and gearing.
- APE Jay
- Banned
- Thank you received: 58
- APE Jay
- Banned
bluezbike wrote: Hi all, I have just acquired a set of Norris cams, they have "Norris 440 SC" engraved on a flat surface and look to be in very good shape....does anyone know anything about these cams?
Do you have a fax number?
- bluezbike
79 KZ 1000 LTD
- racer54
- Thank you received: 114
Norris 440 SC cams:
Duration @ .020 284*
Lift .437
Application is for 1000-1100cc motors that need help in the ft. lbs. department...
They are also listed paired with a .448 lift cam for a 1200cc street motor without a top of the line cylinder head...
Hope this helps...
- bluezbike
79 KZ 1000 LTD
- LarryC
racer54 wrote: According to my old catalog...
Norris 440 SC cams:
Lift .437
Hope this helps...
That's got to be an old Pogue catalog. I've still got mine too
Larry C.
- LarryC
bluezbike wrote: Great info Racer 54 , many thanks. It's looking like this might be a little too much cam for what I am trying to do.... they may end up in the for sale section.
What are you trying to do?
How big is the motor going to be?
What do you have for carburetors?
Is it a J or KZ?
How do you realistically intend to ride the bike?
Larry C.
- APE Jay
- Banned
bluezbike wrote: PM sent Jay
Check your e-mail
Jay
- racer54
