Norris Cams...any info?
- bluezbike
24 Apr 2013 02:18
Hi all, I have just acquired a set of Norris cams, they have "Norris 440 SC" engraved on a flat surface and look to be in very good shape....does anyone know anything about these cams?
79 KZ 1000 LTD
- Garn
Re: Norris Cams...any info?
24 Apr 2013 03:32
Norris cams are a common high lift cam. I have a set for a Z1 series.
The significants of the engraving "440-SC" I don't know.
The best thing to do is measure the standard inlet cam from the tip to the base circle.
For example the standard Z1 cam measures 36.2 mm,
Whereas, my Norris came measures 37.5 mm.
Meaning that the Norris gives an extra 1.3 mm lift.
Too much lift is not good for street use.
Of course, there are other dimensions of the cam the ramp & dwell.
RegardZ.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Sydney Australia
- Motor Head
24 Apr 2013 10:06
Found this using Google search:
www.dragbike.com/forum/showthread.php?51411-Norris-Cam-specs
I always liked the Norris Cams in the old VW motors, they were great. I would think that they are good Cams. Might be a lot for a street motor, depending on displacement and gearing.
- APE Jay
24 Apr 2013 17:53
Norris car cams and motorcycle cams were two different Norris's. They were related to each other.
- APE Jay
24 Apr 2013 17:57bluezbike wrote: Hi all, I have just acquired a set of Norris cams, they have "Norris 440 SC" engraved on a flat surface and look to be in very good shape....does anyone know anything about these cams?
Do you have a fax number?
- bluezbike
25 Apr 2013 01:12
PM sent Jay
79 KZ 1000 LTD
- racer54
25 Apr 2013 03:00
According to my old catalog...
Norris 440 SC cams:
Duration @ .020 284*
Lift .437
Application is for 1000-1100cc motors that need help in the ft. lbs. department...
They are also listed paired with a .448 lift cam for a 1200cc street motor without a top of the line cylinder head...
Hope this helps...
Norris 440 SC cams:
Lift .437
Hope this helps...
- bluezbike
25 Apr 2013 17:39
Great info Racer 54 , many thanks. It's looking like this might be a little too much cam for what I am trying to do.... they may end up in the for sale section.
79 KZ 1000 LTD
- LarryC
25 Apr 2013 18:52racer54 wrote: According to my old catalog...
Norris 440 SC cams:
Lift .437
Hope this helps...
That's got to be an old Pogue catalog. I've still got mine too
Larry C.
- LarryC
25 Apr 2013 19:00bluezbike wrote: Great info Racer 54 , many thanks. It's looking like this might be a little too much cam for what I am trying to do.... they may end up in the for sale section.
What are you trying to do?
How big is the motor going to be?
What do you have for carburetors?
Is it a J or KZ?
How do you realistically intend to ride the bike?
Larry C.
- APE Jay
25 Apr 2013 21:14bluezbike wrote: PM sent Jay
Check your e-mail
Jay
- racer54
26 Apr 2013 00:14
Yep...old Pogue catalog. Keeping those copies comes in handy now and then huh?
