Piston Domes
  • 650ed's Avatar Topic Author
Piston Domes
11 Apr 2013 23:03
#581924
I've seen a number of pictures of different engines being rebuilt, and it brings a question to mind. The tops of new stock pistons are sometimes very rough, but sometimes I see pictures where the tops look to be very smooth or polished. Should piston domes be polished when rebuilding, or doesn't it really matter one way or the other? Ed
  • wireman
  • wireman's Avatar
Re: Piston Domes
11 Apr 2013 23:49
#581925
Id say the surface finish is directly related to amount of machine work done to pistons. :)
  • bountyhunter
  • bountyhunter's Avatar
Re: Piston Domes
12 Apr 2013 02:48 - 12 Apr 2013 02:55
#581934
650ed wrote: I've seen a number of pictures of different engines being rebuilt, and it brings a question to mind. The tops of new stock pistons are sometimes very rough, but sometimes I see pictures where the tops look to be very smooth or polished. Should piston domes be polished when rebuilding, or doesn't it really matter one way or the other? Ed
I polished the tops of my pistons when I did my rebuild using progressively finer sandpaper grits. The theory was that if it was smoother, heavy carbom would not be as likely to accumulate as much..... I should point out, the finest grit I used was about 180. I don't think mirror finishing is a good thing, I was just trying to level the major craters.
Last edit: 12 Apr 2013 02:55 by bountyhunter.
  • bountyhunter
Re: Piston Domes
12 Apr 2013 02:49
#581935
wireman wrote: Id say the surface finish is directly related to amount of machine work done to pistons. :)
The tops appear to have no machining, they look like cast parts and only the critical sizing dimensions are machined. The rest are just cast rough finish.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Re: Piston Domes
12 Apr 2013 08:05
#581951
my mtcs had a smooth top.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • turboking
  • turboking's Avatar
Re: Piston Domes
12 Apr 2013 08:35
#581953
:ohmy: cast vs forged :woohoo: .......forged pistons have smooth machined tops and valve reliefs.....a cast piston usually has valve reliefs built in along with the front pointing installation arrow ...... :huh: all forged pistons like mtc's,JE's have a smooth finish machined top :dry:
:pinch: BTW.forged pistons are stronger than cast
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • wireman
  • wireman's Avatar
Re: Piston Domes
12 Apr 2013 08:36 - 12 Apr 2013 08:42
#581954
Attachment piston.jpg not found
Borrowed this picture off APEs site,this is an aftermarket forged piston.
They get extra machine work done at factory to make the domes and valve notches just right,that and the forging process leaves a denser/smoother surface compared to a casting to start with. :)
Last edit: 12 Apr 2013 08:42 by wireman.
  • wireman
  • wireman's Avatar
Re: Piston Domes
12 Apr 2013 08:53
#581955
The following user(s) said Thank You: peter1958
Re: Piston Domes
12 Apr 2013 09:06
#581957
Cool video! Thanks!
  • dbsuperbiker
  • dbsuperbiker's Avatar
Re: Piston Domes
14 Apr 2013 18:50
#582299
Ideally the piston top is coated with an insulating layer, either ceramic or hard carbon build up. This keeps the heat (heat is power) in the combustion chamber where it can push the piston down harder.
It's not about pretty...it's about HP.
The following user(s) said Thank You: bluezbike, Street Fighter LTD
