using 1428 cases for 1075 kz 1000 cylinder
01 Apr 2013 19:30 - 01 Apr 2013 19:31 #580004 by turboking
has anyone used 1428 bored cases and a kz1000 cylinder without it leaking like the exxon valdez? :dry:
:blink: I'm thinking on doing a solid aluminum 1015 cc base gasket like .030 as the head is decked. Just wondering how long this would be leak free on the street....... :huh: any thoughts on this . i hate to throw a good set of cases to the side....... :pinch:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 01 Apr 2013 19:31 by turboking.
01 Apr 2013 19:32 #580005 by turboking
Replied by turboking on topic using 1428 cases for 1075 kz 1000 cylinder
should of said turbo charged so i know the bottom end will see boost pressure :S
1985 GS 1150E
1983 GS 1100E
01 Apr 2013 19:51 #580008 by Powerstroke_fan
Replied by Powerstroke_fan on topic using 1428 cases for 1075 kz 1000 cylinder
not sure but bet it will leak bad.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
01 Apr 2013 19:59 #580010 by APE Jay
Replied by APE Jay on topic using 1428 cases for 1075 kz 1000 cylinder
Why would it leak? You have just as much block to case seal area as you would with the 1428
01 Apr 2013 22:11 #580044 by etbike3135
Replied by etbike3135 on topic using 1428 cases for 1075 kz 1000 cylinder
Its the stock block that doesnt work with bored cases. They have holes and divits all over the place. I have done some 1260 cases but I really think your asking for it with 1428. The best stock block is the early 73, it had much less open area.
1973 Kawasaki Z1
18 years in dragbikes
01 Apr 2013 22:21 #580052 by Powerstroke_fan
i am sure if jay says it wont leak then he would know.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
01 Apr 2013 22:26 #580056 by les holt
Replied by les holt on topic using 1428 cases for 1075 kz 1000 cylinder
Because a 1428 leaks?
Just saying
Les
02 Apr 2013 07:51 - 02 Apr 2013 07:52 #580136 by LarryC
Replied by LarryC on topic using 1428 cases for 1075 kz 1000 cylinder
turboking wrote: has anyone used 1428 bored cases and a kz1000 cylinder without it leaking like the exxon valdez? :dry:
This product is pretty good for what you're after. www.gasgacinch.com
Larry C.
Last edit: 02 Apr 2013 07:52 by LarryC.
02 Apr 2013 08:22 - 02 Apr 2013 08:23 #580139 by Powerstroke_fan
Well i was under the impression that when you bored it out that big that it would most likely leak. Aint that why people talk about dry blocking? But atleast i feel better cuz i was kinda worried that when i start my fresh 1327 up this week, it would leak. I used three bond on the base gasket so hopefully it wont leak.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 02 Apr 2013 08:23 by Powerstroke_fan.
02 Apr 2013 09:14 #580141 by turboking
hhmmmmmmmm :S I will wait for more input :huh: maybe three bond , I've used gasgacinch for years.
I have seen big cases used with stock cylinders before....just saying they seemed to weep oil. maybe they were sealed bad , I'm not sure. :unsure:
1985 GS 1150E
1983 GS 1100E
02 Apr 2013 09:16 - 02 Apr 2013 09:18 #580142 by turboking
Powerstroke_fan wrote: Well i was under the impression that when you bored it out that big that it would most likely leak. Aint that why people talk about dry blocking? But atleast i feel better cuz i was kinda worried that when i start my fresh 1327 up this week, it would leak. I used three bond on the base gasket so hopefully it wont leak.
The term "dry blocking" is usually for water cooled engines used at the drag strip.....
keep us posted as to any leaks on start up...... :blink:
1985 GS 1150E
1983 GS 1100E
Last edit: 02 Apr 2013 09:18 by turboking.
02 Apr 2013 10:46 - 02 Apr 2013 10:46 #580159 by Hollywoodmx
Replied by Hollywoodmx on topic using 1428 cases for 1075 kz 1000 cylinder
Maybe his case is vintage British.. :whistle: :laugh: :laugh: :P
Sorry I had to poke at the leaksters. B)
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 02 Apr 2013 10:46 by Hollywoodmx.
