Valve cover end seal replacement
- w8lifter21
- Automotive Afficianado
'82 Kawayamazuki 750 (KZ750)
'91 300zx Twin Turbo
'96 Maxima
- wireman
- Thank you received: 299
You might want to check valve clearances at same time while valve cover is off.
- w8lifter21
wireman wrote: You can try removing valve cover and cleaning them up really good then gluing them back in with some 3-bond/yama bond,youll also need a new valve cover gasket.
Good call, I did remember reading to check that. Assuming an adjustment would be needed, are there any parts I should have in advance to minimize downtime? I'll most likely end up doing it over a rainy weekend since its not that bad yet.
'96 Maxima
- Thank you received: 2098
kz.bike-night.com/
Checking valve clearances is the relatively easy part, compared to adjusting the clearances which is more difficult.
If needing adjustment, some disassembly is required in order to access the shims. Which is necessary to determine which size replacement shims are needed.
- Thank you received: 2829
www.z1enterprises.com/ItemDetails.aspx?i...ZX750&item=MAVAP4002
- Matteson
- Thank you received: 6
KZ 900-a4
- LarryC
Patton wrote: Z1 Enterprises lists cam end plugs.
Where did I read on here just recently that posts like this are forbidden :kiss:
Larry C.
- w8lifter21
The bike having 12k on it, opinions on what the valves will be like?
'96 Maxima
- w8lifter21
'96 Maxima
- wireman
Advertisers cant promote themselves,but other people can recommend them.LarryC wrote:
