Valve adjustment (kz400)
  • treitz
  • treitz's Avatar Topic Author
27 Mar 2013 23:09
#579183
Trying to adjust my valves. But not sure what I'm looking for.
Is the gap below the little arm that holds that holds the valve what I'm looking at? If so, I'm WAY of. It's suppose to be around .20mm but its closer to 1/4".
1979 KZ400 - 2-1 Manifold - Mikuni VM34
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Valve adjustment (kz400)
27 Mar 2013 23:38
#579185
Feeler gauge goes between the top of the valve and the little stud that the nut is on.
Use .004 - .005
I'm lazy, I just back the stud with a screw driver off by 1/4 turn and call it good.
It's not exact, but close to factory specs.
Fighting to get even the bent feeler gauges in positition can be aggravating.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • treitz
27 Mar 2013 23:47
#579187
That's encouraging. I was a little worried. Lol.
So you're measuring from the top of the nut to the top of the threaded piece where the flathead goes?
  • Nebr_Rex
  • Nebr_Rex's Avatar
27 Mar 2013 23:53
#579190
No,underneath the rocker arm.
The stud goes all the way thru to touch the top of the valve.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • treitz
28 Mar 2013 00:17
#579194
Super confused. The gap below the rocker arm is about 1/4".
Should it be seated/tight? Or should the rocker arm move up and down freely?
  • Nebr_Rex
  • Nebr_Rex's Avatar
28 Mar 2013 08:26
#579235
Lash is measured between the valve and the stud.
The rocker will move up and down .004-.005.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • Motor Head
  • Motor Head's Avatar
28 Mar 2013 09:14
#579243
I hope you have a service manual for your bike, the Factory one is best. There are copies available foe download on the net. Do a Google search and you will find one.
The motor needs to be set onto the compression stroke, with the Top Dead Center "T" mark aligned. Then both the intake and exhaust valves can be adjusted. As already posted the measurement with the feeler gauge is done under the rocker arm stud, at the contact of the valve stem. If you actually have 1/4" of clearance instead of .004" there is a problem. You probably have a worn cam lobe or rocker arm. You would have been hearing a bunch of noise coming from the cylinder head area. Adjusting the clearance will set the valve lash, but do nothing for a worn part. You may need to pull the valve cover and have a look to see whats worn. That is IF you really have such large clearance.
  • treitz
28 Mar 2013 13:00
#579273
I do have the manual.
After doing a bit more research it appears I am not measuring correctly. I guess the top of the valve, underneath the rocker arm is harder to see than I thought it would be. And I can't even get my feeler gauge in there to measure it. I may just have a professional check it.
28 Mar 2013 15:21
#579286
See these sites for more good info:
kz400.com/
www.armbell.com/forum/index.php?mforum=kz400
Good Fortune! :)
