KZ750 N1 Spectre Won't Start
- jjackson7
I know that's a lot of information and probably my methods are suspect but any help is appreciated.
Jordan.
- Thank you received: 2098
jjackson7 wrote: Okay, I'm new to site and I'm sure I'm gonna get burned on this but I just put my KZ 750 back together after replacing the head gasket, valve adjustment, and new carb diaphragms. I also cleaned the carbs too while I had them off. I'm getting good compression on each cylinder (160-180). Because of this I'm thinking I got the timing right. I cleaned the petcock and now have good fuel flow. There is fuel in each bowl. The battery is six months old and has never ran on the bike but I have tried to charge it periodically. I tried starting fluid and got nothing. I can see spark on all plugs but I'm now suspecting the battery. I'm trying to come up with a good method for troubleshooting this and I really want to get it going myself. Also, put on new 4-1 exhaust but I'm waiting on header gaskets. I just assumed it would leak a little but I could still get it to start.
Jordan.
...good compression...tried starting fluid and got nothing...can see spark on all plugs.... -- would suspect ignition timing; perhaps the advancer is 180° off.
- jjackson7
Thanks,
Jordan.
Some samples of the marks:
The T mark is used incident to cam timing.
- toad
- Thank you received: 7
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- gdprather
- Thank you received: 3
1985 Kawasaki Vucan vn700A1
1983 Kawasaki KZ1100D2 Spectre
- jjackson7
The plugs were not wet when I pulled them to check for spark. Not a good sign huh? I should note that the diaphragms I changed were not OEM. I had to cut the old ones off the slide and add these. The action on the slide seemed good when I was done and could hear some air movement. The carbs were adjusted and working the last time the bike ran.
I started this process because the head gasket started to leak so bad that it wouldn't start and I knew the valve adjustment was due anyway. The previous exhaust was cracked at the crosspiece so decided to replace that too. I hate making this many changes at once but decided it needed all this while it was apart.
On a side note does anyone have a good method for refitting the rubber boots from the airbox to the carb. So far that has been the most irritating part of this repair and I dread pulling the carbs again because of it.
Thanks,
Jordan.
- MFolks
- Thank you received: 540
Here's another method of rubber softening:
Successfully Resurrecting Old Rubber Parts
(Found on the internet)
This subject has been broached before but the author is happy to report success in revitalizing old rubber.
The author have been using a mixture of 30% wintergreen oil (methyl salicylate) and 70% xylene to restore old rubber parts and it works beautifully. This is the same ingredients and proportions for the commercial product Rubber Renue according to the MSDS sheets.
Wintergreen oil is analgesic and liniment for aching muscles and found in most drugstores, pharmacies, health food stores and co-ops.
He gently heated rock hard honda CB carb boots with a heat gun for 30 seconds and dropped them into mason jars with my solution for 12 hours at room temperature. They come soft, pliable and looking good. They have been out of solution for 48 hours now and are still soft and pliable. He soaked smaller rubber parts such as side panel grommets and there extremely soft and may need to soak for less time
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
THIS IS A CHEAPAZZ PORTABLE BATTERY STARTER, IT 100% DE-MYSTIFIES WHETHER THE BATTERY IS THE PROBLEM
I would definitely take Patton's advice though if you've had the head off.
If you have one of these portable jump starters you can eliminate the battery as the source of your non-starting problem in 10 seconds.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- jjackson7
I read back over the manual and my notes and I did line up with the 'T' mark when I was refitting the camshafts.
I'll try to work through some of this tonight and report back.
- jjackson7
- donthaveakawman
- Visitor
