Camshaft Advice - Street KZ900
  • NakedFun
  • NakedFun's Avatar Topic Author
Re: Camshaft Advice - Street KZ900
19 Mar 2013 20:31 - 19 Mar 2013 20:36
#577742
What about 1981 GPZ1100 cams? Are they the same profile as the 83-84?
EDIT: Nope, as far as part numbers they are different according to Kawasaki.com
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
Last edit: 19 Mar 2013 20:36 by NakedFun.
  • racer54
  • racer54's Avatar
19 Mar 2013 21:46
#577753
You are correct...the early cams are different. The 83-84 GPZ cams have .385 lift...or there abouts. According to experts on this site, a stock 1000 head will flow enough to support up to about .360 lift. APE reported on KZRIDER a while back that they have adjustable cam sprockets to use GPZ cams with 15T center cranks.
  • NakedFun
20 Mar 2013 00:42
#577784
Do you know what the lift on the earlier GPZ cams are?
Cory
1976 Kawasaki KZ900
  • APE Jay
  • APE Jay's Avatar
20 Mar 2013 02:02
#577792
We have them in both 30 and 32T
  • Old Man Rock
  • Old Man Rock's Avatar
20 Mar 2013 06:56 - 20 Mar 2013 07:08
#577804
For my latest project on the KZ900, I just recently measured my new to me GPZ cams @ .373" so including caliper tolerance, .375" lift is what they are.... Got the 30 tooth 2 bolt sprockets from Jay....
As Larry knows, I prefer low to mid range torque (acceleration/pull) in my builds & as always, following Larry's guidance ;) for my desires, 108 exhaust & 106 intake on the cam degreeing.
1075cc displacement on it's way back from Joe Hooper....
Should wake the old girl up nicely! B)
Bring it on Harley BIATCH's... :P :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 20 Mar 2013 07:08 by Old Man Rock.
  • NakedFun
20 Mar 2013 11:07
#577827
OMR,
Are those specs from the 83-84 GPZ or the 81-82 GPZ?
Cory
1976 Kawasaki KZ900
  • OnkelB
  • OnkelB's Avatar
20 Mar 2013 12:58 - 20 Mar 2013 13:11
#577848
NakedFun wrote: Do you know what the lift on the earlier GPZ cams are?
Cory
Here you go, courtesy of MFolks:
1981 KZ1100 B1 Gpz:
Intake:
Duration: 280 - Lift: 8,4 mm (.330") - Open: 35 BTDC - Close: 65 ABDC
Exhaust:
Duration: 280 - Lift 8,8 mm (.346") - Open: 68 BBDC - Close: 32 ATDC
1982 KZ1100 B2 GPz:
Intake:
Duration: 288 - Lift: 8,8 mm (.346") - Open: 34 BTDC - Close 74 ABDC
Exhaust:
Duration: 288 - Lift: 8,8 mm (.346") - Open 72 BBDC - Close 36 ATDC
Btw, the 81/82 GPz's run shim over bucket, the 83/84 models run shim under - can't say if shim under is needed for using the 83/84 cams in the 900, but I thought I'd mention it..
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 20 Mar 2013 13:11 by OnkelB.
  • timebomb33
  • timebomb33's Avatar
20 Mar 2013 14:16
#577852
you don't need to go shim under until about .418" lift
I THINK MY POWERBAND BROKE
  • NakedFun
20 Mar 2013 15:09
#577859
Well I may just go ahead and pick up the '82 GPZ cams I found as they are relatively inexpensive. I do have time to wait a bit anyway so I can keep an eye out for the later 83-84 cams...
Cory
1976 Kawasaki KZ900
  • Old Man Rock
21 Mar 2013 09:09
#577970
I don't have the actual spec sheets on them but as far as I know, 83/84 GPZ cams .375 lift 258 duration @ .050. Pretty much what I measured.
And No, I've never measured the 1981/82 cams so going w/Mfolks info is good enough for me.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • NakedFun
23 Mar 2013 10:23
#578299
Well I got a set of '81 GPZ cams for $50 bucks so even though they are not the coveted 83-84 profile, still more lift and duration than my stockers...
Cory
1976 Kawasaki KZ900
  • NakedFun
01 Apr 2013 21:19
#580028
My cams showed up and they do not have tach drive gear on the exhaust cam? Is this normal? Any thoughts to how you setup a tach now? What ave you guys done?
Cory
1976 Kawasaki KZ900
