Camshaft Advice - Street KZ900
- NakedFun
18 Mar 2013 12:15
All,
Looking for a recommendation for a camshaft to be used on a KZ900 street bike. Bike will have jetted VM28 pumpers, aftermarket exhaust, and 1015cc kit with 10.25:1 compression (static)ratio. I have heard the Andrews 2X cams are the ones to have. Any thoughts on that? Any other ones to try? IF the Andrews, anyone know of a set? I have been watching the ads and Ebay....
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- gpz1170
Re: Camshaft Advice - Street KZ900
18 Mar 2013 14:08
Cory
A pair of 83/84 GPZ cams with APE KZ conversion cam sprockets, they make the sprockets for both 15&16 tooth cranks, work really well.
don
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- 4TheKZ1000
18 Mar 2013 14:28 - 18 Mar 2013 14:29gpz1170 wrote: Cory
don
Cory, Don is correct....these are nice cams and with the 28's would be a good street setup.
The GPZ 1983 1100 CAMS came up in my build from John Pearson....he knows alittle about KZ platforms and what works or not.
Last edit: 18 Mar 2013 14:29 by 4TheKZ1000.
- NakedFun
18 Mar 2013 14:56
So I need a set of 83-84 GPZ1100 cams and the adapter sprockets from APE for my roller chain and proper tooth count? Any head clearancing required?
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- donthaveakawman
18 Mar 2013 15:11Not sure if those sprockets are adjustable, if so I suppose if you turned the cams slightly inward toward each other you may gain some horsepower.gpz1170 wrote: Cory
don
- Powerstroke_fan
18 Mar 2013 19:134TheKZ1000 wrote:gpz1170 wrote: Cory
don
Id listen to what john says. He did all my machine work and a few other stuff. Hes a stand up guy. If he told me to let donthaveakawman work on it i would!!! :woohoo: :woohoo: :laugh: :silly:
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- DoubleDub
18 Mar 2013 23:43Powerstroke_fan wrote:4TheKZ1000 wrote:gpz1170 wrote: Cory
don
Now that is a real endorsement LMAO :laugh:
When I think of Donthaveakawman I just want to yell RUN FOREST RUN
- etbike3135
19 Mar 2013 08:21
The 83/84 cams conversion sprockets only come in 32 tooth, so you would need to have a MKII crank with a 16 tooth center pin. Also with those cams you will not be able to use your stock tach because they do not have a tach drive.
1973 Kawasaki Z1
18 years in dragbikes
- LarryC
19 Mar 2013 08:36NakedFun wrote: All,
Cory
They were a good cam for a small cc street bike. Watch carefully when buying used cams off Ebay.
Larry C.
- les holt
19 Mar 2013 19:36
I've got them in my motor with a 15 tooth crank with adjustable sprockets. :evil: :evil: Along with a cavanaugh ported head. :S :S And a big hair dryer going on it.
Les
Attachment turbopiping003.JPG not found
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- NakedFun
19 Mar 2013 19:44
www.kzzone.com
has 15 tooth roller chain, with the two bolt for the GPZ and later cams on their site.
Larry,
Got my quote from Joe at Pit Stop for a full engine rework including 1015 kit. Quite prioey, but not surprising. Other wise, was going to hone the jugs and re-ring it and leave it at a 903. I don't like the stock compression ratio of 8.5:1 though. So either way, the Andrews 2x's would probable work well in my application.
I found a a set of brand new GPZ cams as recommended above, and they are $150 each plus $47 each for shipping from Sweden.... :sick: I am going to keep an eye out for used GPZ's....
Cory
Larry,
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
