KZ750 4-1 exhaust size??
- mike0537
14 Mar 2013 02:32
I am planning on building my own exhaust for my 750. I just want to know what the 4-1 collector output size is? I'm thinking it is around 2". I only have the stock exhaust and would like to know what Kerker, VH, or anyone else used as exhaust size so I can keep it the same for back pressure reasons.
Thanks!
Thanks!
1980 KZ750E
- donthaveakawman
Re: KZ750 4-1 exhaust size??
14 Mar 2013 15:20
take a piece of string, wrap it around the measurement measure it then x it by pie
- slayer61
- KZR FLAG RELAY CARRIER #62
14 Mar 2013 15:26donthaveakawman wrote: take a piece of string, wrap it around the measurement measure it then x it by pie
Divide by PIE :side:
14 Mar 2013 16:43
8 slices = 1 pie
- mike0537
14 Mar 2013 16:44
I don't have the exhaust to measure.....
1980 KZ750E
- geobass
- 75 Z1-B
14 Mar 2013 17:43donthaveakawman wrote: take a piece of string, wrap it around the measurement measure it then x it by pie
Multiply circumference by .3183
I always found it easier to multiply than divide, but then again I come from an era of slide rules!
To the OP I can answer your question tomorrow. I have the Kerker but it is about a half hour away!
George
- slayer61
14 Mar 2013 19:14geobass wrote:donthaveakawman wrote: take a piece of string, wrap it around the measurement measure it then x it by pie
George
:laugh: :laugh: :laugh: :laugh:
You guys are KILLING me! If you had a tape measure, why wouldn't you just measure the ID/OD of the collector! :laugh: :woohoo: :laugh: :silly:
14 Mar 2013 19:30 - 14 Mar 2013 19:30
Mmmmmmmmmmm π
Last edit: 14 Mar 2013 19:30 by 650ed.
- donthaveakawman
15 Mar 2013 04:12
the problem is where the pipes collide it is very small and hard to find a y-pipe to fit.
- wireman
15 Mar 2013 04:39Depends entirely on kind of pie,I generally have found in the case of peach/cherry or pumpkin pie that the 1 pie to 1 fork generally fits into my plans rather well! :woohoo:Patton wrote: 8 slices = 1 pie
- donthaveakawman
15 Mar 2013 04:42
I can put my handle bar in the exhaust pipe and jiggle it around a bit where I cut it off so yes a 7/8" handlebar plus jiggle x (pie x 0) equals about 1 inch x 2 = about 2 inches then the baffles for restrictionary purposes = pumpkin pecan
15 Mar 2013 14:24 - 15 Mar 2013 14:29
Chicken pot pie would involve an entirely different calculus, sort of like pie in the sky, and sometimes pizza pie (if triangular slices and NOT rectangles).
Suggest consultation with the APC:
www.piecouncil.org/
www.piecouncil.org/
Last edit: 15 Mar 2013 14:29 by Patton.
