Valve Leak
- Spectre1982
Valve Leak
06 Mar 2013 22:08 - 06 Mar 2013 22:11
I'm doing a top end rebuild on my KZ. I took off the head and filled the ports with solvent. The solvent slowly seeped out past the valves. I took it apart and upon inspection of the valves and seats I didn't see any pitting. The valves looked new after the wire wheel. I lapped them in a bit to see if that would help. After reassembly the solvent isn't leaking past the valves anymore. However, when I blow compressed air around the valve seat I can see a couple of tiny bubbles come up.
My options are take it apart again for another round of lapping
Or I could send it out for a proper valve job
Or say "good enough" and run it as is.
Should there be absolutely no leakage or are the tiny bubbles acceptable? I'm not rebuilding for performance but I'm not trying to half ass it either.
The bike ran before the tear down. I had 100 psi in the low cylinder and the plug looked a bit oily.
Also, do the valves seat in/bed after running the motor to seal up more?
Thanks
Thanks
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
Last edit: 06 Mar 2013 22:11 by Spectre1982.
- KZ Rat
Re: Valve Leak
06 Mar 2013 22:51
Are you blowing air into the exhaust/intake runners and seeing bubbles in the combustion chambers? You could be forcing the valves open slightly with the air pressure and causing the bubbles?
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
The following user(s) said Thank You: Spectre1982
- wireman
Re: Valve Leak
06 Mar 2013 23:26
Sounds like he filled the port and blew air around edge of valve face and seat,Thats how I do it also.
If it was me Id take it back apart and grind them just enough to get them straight,then lap them some more.
Don't forget to check guides and replace seals while its apart
- Spectre1982
Re: Valve Leak
07 Mar 2013 01:38
Yes, I was blowing air around the edge of the valve face, not through the port.
The guides don't have any discernible wear. The valves are a good fit with basically no side to side movement in the guide. I replaced the guide seals with new Viton seals. It was a pain for the first couple, but I found a good way to get them on.
I suppose I'll do what I should have done the first time and have them cut. I've gone through a lot of trouble to not have it how I want it.
Thanks for the help.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- wireman
Re: Valve Leak
07 Mar 2013 01:47
Its all part of the learning curve
- LarryC
Re: Valve Leak
07 Mar 2013 18:12 - 07 Mar 2013 18:18Spectre1982 wrote: Yes, I was blowing air around the edge of the valve face, not through the port.
After you do that, your lash is going to change. How much depends on how heavy the valves are faced. The valves need tipping after the face cut unless you had really thick shims in there before hand.
If you want to see the true contact pattern of the valve to the seat, use dykem or magic marker. Don't spin the valve when you do that. It will mislead you.
Larry C.
Last edit: 07 Mar 2013 18:18 by LarryC.
- Spectre1982
Re: Valve Leak
07 Mar 2013 18:18
That's a good point.
I'm factoring that in. I'm sure all of them will be out of spec. I'm going a bit over budget for my project, but I sure know my engine well!!! :silly:
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- LarryC
Re: Valve Leak
07 Mar 2013 18:20Spectre1982 wrote: That's a good point.
A light face cut can sink the valve .010" real quick....
Larry C.
The following user(s) said Thank You: wireman, Spectre1982
- Spectre1982
Re: Valve Leak
06 Apr 2013 13:26
Finally got around to putting everything back together. After the valve job, I needed six new shims. All the clearances are set right at the max. It ticks over like a Swiss watch. I put 50 miles on it and the motor feels great. Compression is even across all the cylinders and it hasn't blown up on me yet.
Thanks for all the help!
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- LarryC
