Clutch problem
- turboking
Re: Clutch problem
17 Feb 2013 22:59 - 17 Feb 2013 23:01stewtam wrote: So far Iam not a big fan of after market clutch plates eather,I will re check them to see if they are hanging up or not if they are should i file the basket?
NO file the offending fiber tangs.......... it should be obvious which one/ones it is :pinch:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
Last edit: 17 Feb 2013 23:01 by turboking.
- turboking
Re: Clutch problem
17 Feb 2013 23:02
the aluminum tangs are much softer than the steel basket :dry:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- turboking
Re: Clutch problem
17 Feb 2013 23:06 - 17 Feb 2013 23:11
I would rather use old good OEM fibers than new after market junk for street use. Flea bay has OEM fibers all the time cheap...... :laugh:
and make sure none of the disc's are broken/ cracked as that will cause dragging... :huh:
and soak your clutch :blink:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
Last edit: 17 Feb 2013 23:11 by turboking.
Re: Clutch problem
17 Feb 2013 23:49
For the KZ650 the clutch spring bolt torque spec is 78-95 INCH pounds. That is not a lot of torque. If you tightened yours down too tight that could contribute to the problem. Take a look in the FSM torque table, you should be able to find the spec for your model. Ed
- wireman
Re: Clutch problem
18 Feb 2013 00:55
Check the slots in drum while discs are out just to make sure theres no burrs or grooves worn into them also for discs to hang up on,its more of an issure with extra plates which are thinner than stock plates
The following user(s) said Thank You: stewtam
Re: Clutch problem
18 Feb 2013 01:16 - 22 Feb 2013 23:11
The reported clutch issue would likely be resolved, or greatly diminished, by a proper clutch push-rod adjustment (see earlier posts in this thread).
Would suspect the gap is too large, and thereby wasting part of the hand lever pull by simply closing the gap, before starting to spread the clutch plates.
Last edit: 22 Feb 2013 23:11 by Patton.
- gd4now
- Denco where did you go?
Re: Clutch problem
18 Feb 2013 02:41
Did the replacement clutch come with additional disks/plates? I know some of them do and if you do not install all of the new disks then the set will not take up enough space (not equal to original) and you can have the type of problems you are having.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- stewtam
Re: Clutch problem
22 Feb 2013 22:45
Hey all I finally got a chance to get back to work on my clutch problem. I checked how tight my pressure plate bolts were,and found I had one a little bit tighter then the rest. I loosened all of them and torqued them to 90 inch pounds so far the clutch is working great. Thank You all for your Help.
