- Thank you received: 797
bore job questions?
08 Feb 2013 11:05 #571474
by 531blackbanshee
Replied by 531blackbanshee on topic bore job questions?
KAWASAKI KZ1000J 1981-'97 / GPZ1100 1981-'82 (17mm pin)
All of the pistons listed here are for use with the 1000J model 1980 thru 1997, and early GPZ1100 1980-'82. J model GPZcrankshaft and connecting rods with 17mm pin bores, and std J/GPZ length, unless otherwise stated. Compression ratios are figured on J model 1981 thur '97 and/or early GPZ1100 1981-'82 cylinder head unless otherwise stated.
DISPLACEMENT BORE SIZE COMP RATIO PART# MFG CODE REQUIREMENTS PRICE
1075cc 2.835"
72MM 10.25:1 K1076 1000J cylinder boring only. Largest kit for stock sleeves.. Includes head gasket 565.05
1075cc 2.835"
72MM 12.5:1 JK1075H 1000J cylinder boring only. Largest kit for stock sleeves. oversize 525.00
1170cc 2.953"
75MM 10.25:1 K1171 GPZ 1100 cylinder boring only. Largest kit for stock sleeves.. Includes head gasket 577.70
1260cc 3.071"
78MM 10.5:1 KJ1261 KA750-1 sleeves required. Largest kit for use in stock GPZ1100 cylinder block. 525.00
1327cc 3.150"
80MM 10.5:1 KJ1327 APE Big Block Cylinder Required. 525.00
1327cc 3.150"
80MM 13.5:1 KJ1327H APE Big Block Cylinder Required. 525.00
1500cc 3.346"
85MM Pro Stock
18mm pins MAX CK127 APE Big Block Cylinder Required.For use with Vortex 2 cylinder head. More piston details. Includes head gasket 733.66
it looks as tho 1075 is as big as you can go in your stock j-model cylinders.
i copied this info from kzzone.com/pistons.html
hth,
1075cc 2.835"
1075cc 2.835"
1170cc 2.953"
1260cc 3.071"
1327cc 3.150"
1327cc 3.150"
1500cc 3.346"
85MM Pro Stock
hth,
The following user(s) said Thank You: wireman, fizzer_$tfighter
- fizzer_$tfighter
- YAMASAWKI MAN
08 Feb 2013 13:28 #571491
by fizzer_$tfighter
82 KZ 1000 J Model
Replied by fizzer_$tfighter on topic bore job questions?
Thank you for actual clear help lol
82 KZ 1000 J Model
08 Feb 2013 16:08 #571501
by 531blackbanshee
happy to help.
The following user(s) said Thank You: fizzer_$tfighter
