- Thank you received: 2
Kz650 valve stem seal replacement
- gbot9000
The bike only has ~10,000 miles on it so im hoping its not the guides..
Maybe needs viton stem seals?
Compression check showed
#1-114 #2-110 #3-110 #4-111
Left spark plug, how i got it. Right spark plug, after ~100miles.
Attachment uploadfromtaptalk1360023458115.jpg not found
Attachment uploadfromtaptalk1360023483006.jpg not found
Also what level do you rate changing valve stem seals as far as DIY?
This is my first bike and never worked on a motorcycle before except changed oil and spark plug . I am quite handy and have found some people using the "rope trick" so they do not have to take off the head. What tools would i need? Valve keeper? www.amazon.com/gp/aw/d/B0012S61IO/ref=mp...22554&sr=8-2&pi=SL75
79 kz650
- Thank you received: 2829
- bountyhunter
- Thank you received: 337
Be sure to get VITON seals. The butyl rubber seals do fail, my bike is on it's third set (seem to last about ten years). Vitons are much better.
FYI: I bought a set of valve guides to use when I did my rebuild at 75k miles and the guides all measured like new. Still have the new guides available at a discount.....
- wireman
- Thank you received: 299
wireman wrote: Yeah if they will be able to actually replace all the seals in 2 hrs from start/finish Id pay to buy a ticket and watch these guys work.
Good point; they should make a video.
- turboking
- Thank you received: 106
I see your running ngk b-7 (hotter) to keep from oil fouling? :blink: . the 650 can use ngk b7es :evil: or ngk b8es (standard plug) like the big fours I thought :huh: .
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- wireman
- gbot9000
I found these, should work.
item.mobileweb.ebay.com/viewitem?itemId=230759695057
So he really wouldnt be able tell if the guides are worn when he changes the seals?
I guess if the problem persists after the new seals are in then its probably the guides.
79 kz650
- gbot9000
turboking wrote: sounds like a "quick and dirty" with no head removal. At $140 if he's r&r the head ,it's a steal.
They are the b7es.
79 kz650
They are the b7es.
B7ES is the correct heat range for normal riding. Ed
- APE Jay
- Banned
- Thank you received: 58
The motor has not been "gone through" if the head has just been washed up and valves lapped.
- Motor Head
- Thank you received: 391
The stem seals can be changed with the Head On, but you sound as per compression #'s and the plug reading that you need to look further.
