Carbon Cleaners
- donthaveakawman
Re: Carbon Cleaners
06 Feb 2013 02:21
take out the plugs and spray carb cleaner in the cylinders. warning you may need to change your oil after due to the solvent going past the pistons.
- donthaveakawman
Re: Carbon Cleaners
06 Feb 2013 02:26
there was an occasion where I dumped a half container of lucas fuel additive in my bike and forgot about it. When I started it the next day i about threw a fit thinking there was dirty oil dripping out of the exhaust, so I called around looking for parts.
- grumpy56
Re: Carbon Cleaners
06 Feb 2013 10:31
Appreciate the info. I've been using a few oucnes of Seafoam about every 500 miles, but always wondered if there was somehting else I should do. Thanks again.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- KZ_KLR
Re: Carbon Cleaners
06 Feb 2013 11:29
One more suggestion:
Redline fuel treatment
more aggressive than Seafoam
- donthaveakawman
- donthaveakawman
Re: Carbon Cleaners
07 Feb 2013 03:03
I put about 4 ounces of marvel mystery oil in my tank a couple days ago.(4 ounces treats up to 10 gallons) the last 3 times I filled it up probably equals 10 gallons or so. I am going to wait for it to cool down(two hour ride) and pull the spark plugs to get a look-see at the cylinders.
- donthaveakawman
Re: Carbon Cleaners
07 Feb 2013 03:37
I have inspected the plugs and 400 miles is too soon to tell if they are fouled. the carbon on the pistons is on top of the pistons no problem there if it doesn't need to b pulled apart why not just leave it. other than that I put some carb cleaner in the cylinders which is probably in the oil now.
- lushbaugh
- everybodys a pro......
Re: Carbon Cleaners
08 Feb 2013 20:01donthaveakawman wrote: seafoam works for me. get a few t-fittings and link some vacuum hoses together, then dip the vacuum hoses in the can of sea foam while it is running then rev it. I did it yesterday and it seems to run better.
told ya
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- donthaveakawman
Re: Carbon Cleaners
11 Feb 2013 03:59
actually the sea foam cleared out the carbon of my #2 cylinder now I have no compression. its all your fault.
