Carbon Cleaners
- grumpy56
Carbon Cleaners
04 Feb 2013 20:36
Have any of you boys used any sort of carbon build-up cleaning products on your KZs? Brands? Results? Cautions? Thanks, Lew.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- MFolks
Re: Carbon Cleaners
04 Feb 2013 20:45
I'll give you my listings for engine chemicals:
Mopar Combustion Chamber Cleaner # 04318001. Designed to remove carbon from combustion chambers & valves.
www.amazon.com/Yamaha-Combustion-Chamber...r-13oz/dp/B002GUCLFY ACC110008200 Features: Laboratory and field-tested blend of chemicals to remove power-robbing deposits that accumulate in gasoline engines.
www.valvoline.com/products/consumer-prod...uel-system-cleaners/
Kleen flo Combustion Chamber Cleaner STOCK No 823
Purges carbon, gum, varnish, sludge from internal parts. Helps increase gas mileage. Oxygen sensor and catalytic converter safe. Improves engine work. Can be used in exhaust catalyst system.
www.amazon.com/Yamaha-Carburetor-Cleaner...-CARBC/dp/B002GU4SPA Yamaha Carb Cleaner # ACC-CARBC-LE-NR
www.amazon.com/Yamaha-Ring-Additive-32oz-ACC-
RNGFR-32-00/dp/B002GUCLH2 (Yamaha Ring Free)
www.barsproducts.com/E10L.htm
www.seafoamsales.com/motor-treatment.html Seafoam Oil And Gasoline Additive.
www.seafoamsales.com/sea-foam-spray.html
www.gmpartsdirect.com/results.cfm?single...&partnumber=88861011 (Fuel System Treatment Plus)
The following user(s) said Thank You: bluezbike
- donthaveakawman
Re: Carbon Cleaners
04 Feb 2013 20:47
seafoam works for me. get a few t-fittings and link some vacuum hoses together, then dip the vacuum hoses in the can of sea foam while it is running then rev it. I did it yesterday and it seems to run better.
- bountyhunter
Re: Carbon Cleaners
05 Feb 2013 02:37Free carbon can be removed with a wide range of cleaners, even the simple orange stuff.grumpy56 wrote: Have any of you boys used any sort of carbon build-up cleaning products on your KZs? Brands? Results? Cautions? Thanks, Lew.
Burned on hard carbon is a different story, never found anything that removes it without attacking metal. That is my Holy Grail as I have searched in vain for any cleaner that would dissolve burned on carbon from revolver cylinders or gun barrels.....it would be worth it's weight in platinum. :lol:
- bountyhunter
Re: Carbon Cleaners
05 Feb 2013 02:45
FYI, this stuff absolutely does NOT WORK. Guess how I found out.....
www.slip2000.com/slip2000_carbon_killer.php
- wireman
Re: Carbon Cleaners
05 Feb 2013 03:15
Toss a big can sea foam in the tank then take it out on an open stretch of back highway and run it through the gears keeping the r's up for a couple miles in 4th gear,youll notice the differance
- donthaveakawman
Re: Carbon Cleaners
05 Feb 2013 04:08Attachment mufflerbearing.jpg not found
you can also find big exhaust leaks with sea foam in the intake, as it will smoke alot.
- KZ250LTD
Re: Carbon Cleaners
05 Feb 2013 04:54
I'm always careful about recommending carbon cleaner for combustion chambers. Keep in mind that whatever carbon is removed has to go somewhere. If you've got a layer of caked-on carbon and some of it comes off b/c of the cleaner, you have to hope that that chunk makes it out the exhaust valve without getting caught in the seat and bending the valve-stem or alternatively getting caught between the piston and wall and scoring up your cylinder.
79 KZ1000ST
Past:
Many.
Past:
Many.
- donthaveakawman
Re: Carbon Cleaners
05 Feb 2013 08:48
good thinking, we must find something to dissolve the carbon.
- wireman
Re: Carbon Cleaners
05 Feb 2013 13:42
A spray bottle full of water will also work for cleaning it out
- undiablo
Re: Carbon Cleaners
05 Feb 2013 21:25
I have tried XADO VERY LUBE - ANTI CARBON with fairly good results. I don“t have any proof, but the bike seems to feel better in the range of 2000 to 3500 RPMs. You have to remove sparks, squeeze a tube of the product inside, put again the spark plugs (no boot attached), wait 20 minutes and crank the engine with the starter for 10 seconds. Finally, attach the spark plug boots and fire it up. Tooks several tries to get it alive by the way....
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- guitargeek
Re: Carbon Cleaners
05 Feb 2013 22:51
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
