- Thank you received: 6
Carbon Cleaners
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- MFolks
- Thank you received: 540
Mopar Combustion Chamber Cleaner # 04318001. Designed to remove carbon from combustion chambers & valves.
www.amazon.com/Yamaha-Combustion-Chamber...r-13oz/dp/B002GUCLFY ACC110008200 Features: Laboratory and field-tested blend of chemicals to remove power-robbing deposits that accumulate in gasoline engines.
www.valvoline.com/products/consumer-prod...uel-system-cleaners/
Kleen flo Combustion Chamber Cleaner STOCK No 823
Purges carbon, gum, varnish, sludge from internal parts. Helps increase gas mileage. Oxygen sensor and catalytic converter safe. Improves engine work. Can be used in exhaust catalyst system.
www.amazon.com/Yamaha-Carburetor-Cleaner...-CARBC/dp/B002GU4SPA Yamaha Carb Cleaner # ACC-CARBC-LE-NR
www.amazon.com/Yamaha-Ring-Additive-32oz-ACC-
RNGFR-32-00/dp/B002GUCLH2 (Yamaha Ring Free)
www.barsproducts.com/E10L.htm
www.seafoamsales.com/motor-treatment.html Seafoam Oil And Gasoline Additive.
www.seafoamsales.com/sea-foam-spray.html
www.gmpartsdirect.com/results.cfm?single...&partnumber=88861011 (Fuel System Treatment Plus)
- donthaveakawman
- Visitor
- bountyhunter
- Thank you received: 337
Free carbon can be removed with a wide range of cleaners, even the simple orange stuff.grumpy56 wrote: Have any of you boys used any sort of carbon build-up cleaning products on your KZs? Brands? Results? Cautions? Thanks, Lew.
Burned on hard carbon is a different story, never found anything that removes it without attacking metal. That is my Holy Grail as I have searched in vain for any cleaner that would dissolve burned on carbon from revolver cylinders or gun barrels.....it would be worth it's weight in platinum. :lol:
- bountyhunter
www.slip2000.com/slip2000_carbon_killer.php
- wireman
- Thank you received: 299
- donthaveakawman
- Visitor
Attachment mufflerbearing.jpg not found
you can also find big exhaust leaks with sea foam in the intake, as it will smoke alot.
- KZ250LTD
- Thank you received: 16
79 KZ1000ST
Past:
Many.
- donthaveakawman
- Visitor
- wireman
- undiablo
- Thank you received: 64
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- guitargeek
- Thank you received: 50
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
