750 factory turbo kz
  • DRAGFIGHTERBOB
  • DRAGFIGHTERBOB's Avatar Topic Author
  • DragFighterBob
04 Feb 2013 03:50
#570684
What might it take to put turbo set up on my 77 650b1
Her name SLUTTYBITCH AKA BAMBY
2005 Busa front end stretched and rake 34 degree lowerd 1"
Chopper spoked wheels
Full shaved frame /swingarm,painted lime gold pearlblack
Full custom 15.5 " stretched swing arm w jack shaft
Air ride rear mono shock
Suicide clutch jockey shift
Solo seat w suction rear...
  • wireman
  • wireman's Avatar
Re: 750 factory turbo kz
04 Feb 2013 04:08
#570687
Im not sure if anybody makes an actual 650 kit,you might check 750turbo.com B)
  • les holt
  • les holt's Avatar
  • Vendor
04 Feb 2013 07:56
#570696
There has been a few done, from time to time I'll see turbo exhaust for the 650/750 on ebay. You may have to pc. one together.
Have more pics? That's a sweet looking ride!
Les
  • DRAGFIGHTERBOB
  • DragFighterBob
04 Feb 2013 09:25
#570703
Thanks ill def look round ,
  • DRAGFIGHTERBOB
  • DragFighterBob
04 Feb 2013 09:37
#570704
Would the dyna s ignition i have wrk w the boost i have 26 mm carbs that wrk also? Ima doo more reaseach .. . Theres my 05 10" stretched bigbore zuma w pipe,and all the extras in the drive train, and my 10 " lowerd ruckus also stretched shaved but 11" ,... And my next project the CSR 1000 12000mi runs great very good start im hoping obvi not a 77 but cleaaan
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
04 Feb 2013 10:13 - 04 Feb 2013 10:13
#570705
It's a lot of work to turbo a 650 properly. Kawasaki did the hard work for you when they brought out the 750 turbo, so if you can pick up one of those complete with fuel injection system, loom and exhaust you'll save your self a lot of time and trouble, and it's easy to swap the turbo engine into the 650 frame.
The turbo engine has low compression pistons, stronger rods, stronger gearbox, an oil scavenge pump for the turbo, a larger clutch, electronic ignition, a better cam chain...the list goes on.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
Last edit: 04 Feb 2013 10:13 by Lorcan.
The following user(s) said Thank You: DRAGFIGHTERBOB
  • DRAGFIGHTERBOB
  • DragFighterBob
04 Feb 2013 10:49
#570707
Soo u have a turbo 760 and 810 ? The numbers u have there r givin me hope of poss bein a z1 contender most def niice
  • turboking
  • turboking's Avatar
04 Feb 2013 10:57
#570708
Nice B)
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
04 Feb 2013 15:41
#570733
My 760cc bike was back in the late 1990s. The 810cc bike was last run in 2006. I'm working on a 904cc bike but don't hold your breath waiting for that one :laugh:
760cc - 8.69@162mph
