KZ1000J, Cam Chain Life
Re: KZ1000J, Cam Chain Life
04 Apr 2021 14:17 - 04 Apr 2021 14:18
#846139
Mikaw post=846108 My 78 1000 will make noise if I lower the rpm to much (below 800) It’s backlash in the trans. If I pull in the clutch it gets quiet. I normally keep the idle rpm about 1000 to 1100
Agree!  According to the owner's manual the correct idle speed for the KZ650 is 950 - 1050 rpm.  I keep mine at about 1050 and it doesn't make noise.  If i set it below 1000 rpm it will make some noise.  Ed
Last edit: 04 Apr 2021 14:18 by 650ed.
